Project Drawing Status Tool
youann21700
youann21700
Afternoon,
I am in the market for a new iLogic tool, but my coding is poor. It will hopefully function as follows:
1. Access tool from in Inventor
2. Select the folder you wish to search (Folder within Work/Designs, each is a different company project)
3. The rule searches through all drawing files in the top level of the selected folder.
4. The rule stores specific iProperties from each drawing.
5. Once searched, the tool presents a summary of the iProperties taken from each drawing
The iProperties I will end up taking are to do with our in-house revision control system (we use Vault Basic so developed our own with iLogic). The goal is to have an easily accessible summary of the current revision status of each drawing within a given company project.
if anyone can give any tips on searching a selected folder for .idw files, opening, storing iProperties, and closing, without it being immensely slow that would be very helpful.
WCrihfield
Hi @youann21700.  I have something similar to that which we only use sparingly, once in a while, because we don't have Vault at all yet, even though we have 'talked' about it for years.  Anyways, as it is right now, it first prompts the user to select a folder.  Then gets all IDW type drawing files in that folder (because that's the only drawing file extension we use).  Then it iterates through each file, opens it 'invisibly' (in the background, with no Document tab), so that it can access its iProperties, and retrieves the Part Number and Title iProperty values from each one, and records that data in a 'List of Lists of Strings', so to speak, for use later.  It incorporates an Inventor ProgressBar while this is going on, with its cancel button visible and functioning, so we can cancel the process at any time, if it gets bogged down, or we change our minds about something, because it can take a while.  Then it writes that data to a 'New' Excel spreadsheet, and presents that (without saving it anywhere yet).
So, you may need to make a couple adjustments to it to get it working exactly the way you want it.  This is not a simple task, so the code is not that short or simple, so you will need to spend some time studying it, if you will be maintaining it, and updating it over time.
The code is within the attached Text file, because it is rather large.  But it can be copied, in its entirety, over into a single external iLogic rule.  Then, you can modify it however you want.
Wesley Crihfield
(Not an Autodesk Employee)
youann21700
Ideal thank you, exactly what I was looking for.
I've attached my edited version below, all I changed was the addition of an Input List box to choose your folder instead of the dialog box (purely a UI preference), and changed the properties it searched for in each drawing.
Imports Microsoft.Office.Interop.Excel
AddReference "Microsoft.Office.Interop.Excel.dll"
Sub Main
	'Define main directory
	Dim ofilepath As String = "C:\Work\Designs"
	Dim mainDirectory As IO.DirectoryInfo = New IO.DirectoryInfo(ofilepath)
	' Define a list array to store values of subfolder names & fullnames
	Dim project_name As New ArrayList
	Dim project_path As New ArrayList
	' Loop through each folder and store names/paths in arrays
	For Each folder As IO.DirectoryInfo In mainDirectory.GetDirectories()
		Dim foldername As String = folder.Name.ToString
		Dim folderpath As String = folder.FullName.ToString
		project_name.Add(foldername)
		project_path.Add(folderpath)
	Next
	'give input box to choose project, define selected folder to search for idw files
	ArraySelected = InputListBox("Choose a Project", project_name, project_name.Item(0), "Project", "List of Active Projects", 600, 0)
	If ArraySelected = "" Then
		Return
	End if
	index = project_name.IndexOf(ArraySelected)
	Searchpath = project_path(index)
	'get reference to active Inventor application object one time, then use this variable later
	Dim oInvApp As Inventor.Application = ThisApplication
	'specify the prompt to show the user within the file dialog, when it shows
	Dim sDialogPrompt As String = "Choose folder to create Excel report for."
	'run our custom Function to allow user to use a file dialog to select a folder.
	Dim sFolder As String = Searchpath
	'check if anything was returned, and if something was returned, make sure it is valid
	If sFolder = "" Then
	MsgBox("Empty path returned for Folder.  Exiting rule.", vbCritical, "iLogic")
	Return 'this exits out of this current Sub routine
	ElseIf IsValidPath(sFolder) = False Then
		MsgBox("Specified Folder path was not valid.  Exiting rule.", vbCritical, "iLogic")
		Return
	'make sure that folder exists
	If System.IO.Directory.Exists(sFolder) = False Then
	MsgBox("Specified Folder does not exist.  Exiting rule.", vbCritical, "iLogic")
	Return
	'Dim oDirectoryInfo As New System.IO.DirectoryInfo(sFolder)
	'get an Array of Strings containing the full file names of every file in this folder with ".idw" file extension
	Dim sFileExtensionsFilter As String = "*.idw"
	Dim oFiles() As String = {}
	Try
		oFiles = System.IO.Directory.GetFiles(sFolder, sFileExtensionsFilter, System.IO.SearchOption.TopDirectoryOnly)
	Catch
		MsgBox("Error getting the files from within the specified folder!", vbCritical, "iLogic")
	End Try
	Dim iFiles As Integer = oFiles.Length
	'make sure we found some files like that in that folder...if not, exit this rule
	If oFiles Is Nothing OrElse iFiles = 0 Then
	MsgBox("No IDW drawing files found in that folder.  Exiting rule.", vbCritical, "iLogic")
	Return
	'declare a collection type variable to hold all the data we want to record
	Dim oDataList As New List(Of List(Of String))
	'define column headers as first entry into that data
	Dim oColumnHeaders As New List(Of String) From {"PART NUMBER", "Revision Number", "DRW", "Checked", "Approved" }
	'add the column headers to the main collection, as its first entry
	oDataList.Add(oColumnHeaders)
	'define options for what should happen when opening the drawings
	Dim oOpenArgs As Inventor.NameValueMap = oInvApp.TransientObjects.CreateNameValueMap
	oOpenArgs.Add("DeferUpdates", True)
	oOpenArgs.Add("FileVersionOption", FileVersionEnum.kOpenCurrentVersion)
	oOpenArgs.Add("SkipAllUnresolvedFiles", True)
	'create the 'ProgressBar' and provide starting information to it
	oProgressBar = oInvApp.CreateProgressBar(False, iFiles, "Searching Files", True)
	'create a variable to keep track of which 'step' we are on, for 'Progress' purposes
	Dim iFile As Integer = 0
	'call our custom routine to initialize / update the ProgressBar
	UpdateProgressBarMessage(0, iFiles)
	'iterate through those this array of full file names
	For Each sFile In oFiles
		'check if the ProgressBar has been canceled.  If so, then exit this loop immediately.
		If bProgressBarCancelled = True Then
		oProgressBar.Close()
		Exit For
		ElseIf iFile >= iFiles Then
		iFile += 1 'adds 1 to its current value (for 'Progress' tracking purposes)
		'let the ProbressBar know which step we are about to process
		UpdateProgressBarMessage(iFile, iFiles)
		'declare variable to hold the Document we will be opening
		Dim oDDoc As DrawingDocument = Nothing
		'try to open that Document, based on the FullFileName, using the Options established
		Try
			oDDoc = oInvApp.Documents.OpenWithOptions(sFile, oOpenArgs, False) 'False = not visible
		Catch
			MsgBox("Error opening following drawing file." & vbCrLf & sFile, vbCritical, "iLogic")
		End Try
		If oDDoc Is Nothing Then Continue For 'skip to next 'sFile', if any
		'get Part Number iProperty value
		Dim sPN As String = oDDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
		If sPN = "" Then
		'we could still write the empty string to the cell in Excel, or we could omit this file
		'get REV NUmber iProperty value
		Dim sRN As String = oDDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
		If sRN = "" Then
		'get DRW iProperty value
		Dim customPR As PropertySet
		customPR = oDDoc.PropertySets.Item("Inventor User Defined Properties")
		Dim sDRW As String
		Try
			sDRW = customPR.Item("DRW").Value
		Catch
			sDRW = ""
		End Try
		'get CHKD iProperty value
		Dim sCHKD As String
		Try
			sCHKD = customPR.Item("CHKD").Value
		Catch
			sCHKD = ""
		End Try
		'get APPD iProperty value
		Dim sAPPD As String
		Try
			sAPPD = customPR.Item("APPD").Value
		Catch
			sAPPD = ""
		End Try
		'create a new List(Of String), and add these pieces of data to it
		Dim oRowData As New List(Of String) From {sPN, sRN, sDRW, sCHKD, sAPPD }
		'add that new List(Of String) to the main data collection
		oDataList.Add(oRowData)
	Next sFile
	'make sure the ProgressBar gets closed if Progress is finished
	If iFile >= iFiles Then : Try : oProgressBar.Close() : Catch : End Try : End If
	'convert List(Of List(Of String)) Into a 2-dimensional Array of Strings [ String() ]
	Dim iRowsOfData As Integer = oDataList.Count
	Dim iColumnsOfData As Integer = oDataList.Item(0).Count
	Dim oDataArray((iRowsOfData - 1), (iColumnsOfData - 1))
	For iRow As Integer = 0 To (iRowsOfData - 1)
		For iColumn As Integer = 0 To (iColumnsOfData - 1)
			oDataArray(iRow, iColumn) = oDataList.Item(iRow).Item(iColumn)
		Next iColumn
	Next iRow
	'now we need to write the data we collected from those files into an Excel file.
	Write2DArrayOfDataToExcel(oDataArray)
End Sub
Dim WithEvents oProgressBar As Inventor.ProgressBar
Dim bProgressBarCancelled As Boolean
Function SelectFolder(Optional sPrompt As String = vbNullString) As String
	If String.IsNullOrEmpty(sPrompt) Then sPrompt = "Select Folder"
	Dim oResult As System.Windows.Forms.DialogResult
	Dim sPath As String
	Using oFDialog As New System.Windows.Forms.FolderBrowserDialog()
		oFDialog.Description = sPrompt
		oFDialog.ShowNewFolderButton = True
		Dim designsfolder As String = "C:\Work\Designs\BP-46 BP Machar W122 Re-Entry Hub Removal Tooling"
		oFDialog.SelectedPath = designsfolder
		'oFDialog.RootFolder = System.Environment.SpecialFolder.MyComputer
		oResult = oFDialog.ShowDialog()
		sPath = oFDialog.SelectedPath
	End Using
	If oResult = System.Windows.Forms.DialogResult.OK Then
		Return sPath
	Else 'if dialog was canceled or something else
		Return String.Empty
End Function
Function IsValidPath(ByVal sPath As String) As Boolean
	If sPath Is Nothing OrElse sPath = "" Then Return False
	If sPath.Intersect(System.IO.Path.GetInvalidPathChars()).Any() Then Return False
	Return True
End Function
Sub Write2DArrayOfDataToExcel(oData(, ) As Object)
	Dim oExcel As Object = Nothing
	Try : oExcel = GetObject("Excel.Application") : Catch : End Try
	If oExcel Is Nothing Then
		Try : oExcel = CreateObject("Excel.Application") : Catch : End Try
		MsgBox("Could not obtain an instance of the Excel application to work with!", vbCritical, "iLogic")
		Return
	If Not TypeOf oExcel Is Microsoft.Office.Interop.Excel.Application Then
		Try
			oExcel = DirectCast(oExcel, Microsoft.Office.Interop.Excel.Application)
		Catch
			MsgBox("Error:  Could not 'Cast' obtained Excel object to 'Excel.Application' Type!", vbCritical, "iLogic")
		End Try
	oExcel.Visible = True
	oExcel.DisplayAlerts = True
	Dim oWB As Object = Nothing
	Try
		oWB = oExcel.Workbooks.Add()
	Catch
		Logger.Error("Error adding a new Workbook in Excel!")
	End Try
	If oWB Is Nothing Then
		MsgBox("Could not create a new Workbook in Excel to write the data to!", vbCritical, "iLogic")
		Return
	Dim oWS As Object = Nothing
	Try
		oWS = oWB.Worksheets.Add()
	Catch
		Logger.Error("Error adding a new Worksheet in Excel!")
	End Try
	If oWS Is Nothing Then
		MsgBox("Could not create a new Worksheet in Excel to write the data to!", vbCritical, "iLogic")
		Return
	Dim iRow As Integer = oData.GetLength(0)
	oWS.Range("A1", "E" & iRow.ToString).Value = oData
	oWS.Columns.AutoFit()
	oWS.Name = "INVENTOR DRAWINGS"
	For Each oOtherWS In oWB.Worksheets
		If oOtherWS IsNot oWS Then oOtherWS.Delete()
	Next oOtherWS
	oWS = Nothing
	oWB = Nothing
	oExcel = Nothing
End Sub
Sub UpdateProgressBarMessage(Optional iStep As Integer = 0, Optional iSteps As Integer = 0)
	oProgressBar.UpdateProgress()
	oProgressBar.Message = "Working on " & iStep & " of " & iSteps & " files."
End Sub
Sub OnCancelProgressBar() Handles oProgressBar.OnCancel
	oProgressBar.Message = "Stopping progress, due to cancelation."
End Sub
