Progressive Tooltip on button
Please help! how to set to ProgressiveToolTip.Image Property for my new Inventor add-in ?
 Dim mbp10 As ProgressiveToolTip
 mbp10 = m_featureCountButtonDef10.ProgressiveToolTip
 mbp10.Title = "main title"
 mbp10.Description = "description for main title"
 mbp10.ExpandedDescription = "extended description for main title"
 mbp10.Image= ???  (as object)
thank you.
how add image to ProgressiveToolTip?
xiaodong_liang
Autodesk Support
Autodesk Support
ControlDefinition.ProgressiveToolTip  provides access to enhanced tooltip display for controls in the ribbon interface. Following is a demo. You can see how to set the image.
Public Sub ProgressiveToolTips()
  Dim g_FilePath As String
  g_FilePath = "C:\temp\"
    ' Create the button definition.
    Dim smallIcon As IPictureDisp
    Set smallIcon = LoadPicture(g_FilePath & "SmallProgTooltip.bmp")
    Dim largeIcon As IPictureDisp
    Set largeIcon = LoadPicture(g_FilePath & "LargeProgTooltip.bmp")
    Dim buttonDef As ButtonDefinition
    Set buttonDef = ThisApplication.CommandManager.ControlDefinitions.AddButtonDefinition("Sample", "SampleCommand", kQueryOnlyCmdType, "", "Sample command to show progressive tool tips.", "Sample", smallIcon, largeIcon)
    ' Add a control to the Work Feature panel of the Model tab of the Part ribbon.
    Call ThisApplication.UserInterfaceManager.Ribbons.Item("Part").RibbonTabs.Item("id_TabModel").RibbonPanels.Item("id_PanelA_ModelWorkFeatures").CommandControls.AddButton(buttonDef, True)
    ' Define the progressive tooltip.  This would typically be done in the
    ' same section of code where the button definition is created but there's
    ' a problem with the beta version where the progressive tooltip can only
    ' be defined on a control has been created.
    With buttonDef.ProgressiveToolTip
        .Description = "The short description."
        .ExpandedDescription = "This is the long expaned version of the description that could have a more complete description to accompany the picture."
        Dim progImage As IPictureDisp
        Set progImage = LoadPicture(g_FilePath & "ProgTooltip.bmp")
        .Image = progImage
        .IsProgressive = True
        .Title = "Sample"
    End With
End Sub
