Programaticaly Pressing Skip all on Resolve Link dialog
Hi
I am writing a batch process that needs to open a idw file. However, I do not have access to the files referenced, so get the resolved Link dialog. If I manually select ‘skip all’ the batch process goes on and works fine; so how do I either Prevent the dialog appearing or Programmatically select skip all
Have you played with silentoperation? I am not sure what it would do in that case but
might be worth looking into?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"steven_evans" wrote in message
news:f1718c9.-1@WebX.maYIadrTaRb...
> Hi
'skip all' the batch process goes on and works fine; so how do I either Prevent the dialog
And if it does, you should be able to turn in on in the middle of the
operation (I.E. creating your own Skip All). Its worth a try anyway.
