Problem with opening 3d dxf in Inventor by VBA. Possible bug in dwg/dxf translator
MaciejWojda
MaciejWojda
As in title: How to open 3d dxf in Inventor by VBA?
I tried different ways, but nothing works well.
If I manage to open somehow, I only get 2d drawing. It's not enough, as I need to capture picture of 3d isometric view.
I hope that someone can help me.
Thanks in advance,
Maciej Wojda
MaciejWojda
Well, I have such function as below:
Public Function ImportDXF(filePath As String) As Document
  Dim DXFAddIn As TranslatorAddIn
  Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
  Dim oContext As TranslationContext
  Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
  oContext.Type = kFileBrowseIOMechanism
  Dim oOptions As NameValueMap
  Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
  oOptions.Value("Import_Acad_IniFile") = dwgImportConfig
  Dim oDataMedium As DataMedium
  Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
  oDataMedium.MediumType = kFileNameMedium
  oDataMedium.filename = filePath
  Dim oDoc As Document
  Call DXFAddIn.Open(oDataMedium, oContext, oOptions, oDoc)
  oDoc.Close (True)
  Set ImportDXF = ThisApplication.ActiveDocument
End Function
 When it comes to line 21 that tries to open a file, a message box appears with description such as:
You cannot open DWG file. If the file os opened in AutoCAD or another application, close it and try again.
The file I try to open is not opened by other software, of course.
After closing the msgbox, run-time error appears: "Method 'Open' of object 'TranslatorAddin' failed"
When I try to make import manually it works, while using the same .ini file.
Does anyone have some idea what's wrong?
The same function (with appropriate .ini file) works well for dwg files.
It looks like some bug in the translator, but maybe I miss something?
Best regards,
Maciej Wojda
