Problem with GeneralDimensions.AddLinear an SketchLine3D
The DrawingView show an Construction with a occurence, which hold an 3DSketch with 3DSketchLines. This 3DSketchLines are the Elements, which are identified by startPoint and endPoint. This Lines are the geometrical objects which i have to dimension. The sketch with this Lines would be included as Sketch3DProxy in oBaseView (and all SketchLine3D as SketchLine3DProxy too, but I'm not shure if have to do this).
The Script found the correct Lines, the Sketch are included, the GeometryIntent are created but the GeneralDimensions.AddLinear-function are failed. I have tried various methods to create the Intent, but nothing changed. Every call failed.
Anyone who know a solution for this problem?
AS
PS: startPoint and endPoint are own Objects with X,Y and Z Values in mm
public void DrawDimension(
            Point startPoint,
            Point endPoint)
if (_oDrawDoc.DocumentType == DocumentTypeEnum.kDrawingDocumentObject && _oActiveSheet != null)
     DrawingView oBaseView = _oActiveSheet.DrawingViews[1];
     Inventor.TransientGeometry oTG;
     oTG = _InvApp.TransientGeometry;
     Inventor.DimensionStyle oDimStyle = null;
     Inventor.Layer oDimLayer = null;
     try
         oDimLayer = _oDrawDoc.StylesManager.Layers[dimStyleName];
         oDimStyle = _oDrawDoc.StylesManager.DimensionStyles[layerName];
     catch
         oDimLayer = _oDrawDoc.StylesManager.Layers["Bemaßung (ISO)"];
         oDimStyle = _oDrawDoc.StylesManager.DimensionStyles["Standard Linear-SINGLE"];
      //jetzt Liniensegment suchen
     try
          //skizze finden und mit einbinden;
          Sketch3D Sketch = null;
          Sketch3DProxy SketchProxy = null;
          Object tempProxy = null;
          ComponentOccurrence oOcc = null;
          if (_RoutingDocument != null && _RoutingDocument.ComponentDefinition.Sketches3D.Count.Equals(1))
               ComponentOccurrences oOccs =                            ((AssemblyDocument)oBaseView.ReferencedDocumentDescriptor.ReferencedDocument).ComponentDefinition.Occurrences;
               for (int i = 1; i <= oOccs.Count; i++)
                    if (oOccs[i].Definition.Document.Equals(_RoutingDocument))
                          oOcc = oOccs[i];
                          oOccs[i].CreateGeometryProxy(((PartDocument)oOccs[i].Definition.Document).ComponentDefinition.Sketches3D[1], out tempProxy);
                          SketchProxy = (Sketch3DProxy)tempProxy;
                          oBaseView.SetIncludeStatus(SketchProxy, true);
                          foreach (SketchLine3D sline in ((PartDocument)oOccs[i].Definition.Document).ComponentDefinition.Sketches3D[1].SketchLines                          {
                              try
                                   Object tmpObj = null;
                                   SketchLine3DProxy slineProxy = null;
                                   oOccs[i].CreateGeometryProxy(sline, out tmpObj);
                                   slineProxy = (SketchLine3DProxy)tmpObj;
                                   try
                                        oBaseView.SetIncludeStatus(slineProxy, true);
                                   catch { }
                                catch { }
                            break;
                _oActiveSheet.Update();
            SketchLine3DProxy dimLine = null;
            Point invStartPoint = oTG.CreatePoint(startPoint.X / 10, startPoint.Y / 10, startPoint.Z / 10);
            Point invEndPoint = oTG.CreatePoint(endPoint.X / 10, endPoint.Y / 10, endPoint.Z / 10);
            foreach (SketchLine3DProxy line in SketchProxy.SketchLines3D)
                if (((SketchPoint3D)line.StartPoint).Geometry.DistanceTo(invStartPoint) < 0.01 ||                                ((SketchPoint3D)line.StartPoint).Geometry.DistanceTo(invEndPoint) < 0.01)
                      if (((SketchPoint3D)line.StartPoint).Geometry.DistanceTo(invStartPoint) < 0.01 &&                                    ((SketchPoint3D)line.EndPoint).Geometry.DistanceTo(invEndPoint) < 0.01)
                           dimLine = line;
                      if (((SketchPoint3D)line.EndPoint).Geometry.DistanceTo(invStartPoint) < 0.01 &&                                    ((SketchPoint3D)line.StartPoint).Geometry.DistanceTo(invEndPoint) < 0.01)
                           dimLine = line;
                 if (dimLine != null)
                       break;
             try
                 Inventor.GeometryIntent oStart = null;
                 Inventor.GeometryIntent oEnd = null;
                 Inventor.DrawingCurve oCurve = null;
                 foreach (Inventor.DrawingCurve Curve in
                                oBaseView.get_DrawingCurves(null))
                     Boolean bUseThis = false;
                     if (Curve.CurveType != CurveTypeEnum.kLineCurve &&
                         Curve.CurveType != CurveTypeEnum.kLineSegmentCurve)
                                    continue;
                     if (Curve.ModelGeometry is SketchLine3DProxy)
                         try
                             SketchLine3DProxy tmpLine = (SketchLine3DProxy)Curve.ModelGeometry;
                             if (tmpLine.Equals(dimLine))
                                  foreach (Inventor.DrawingCurveSegment oSeg in Curve.Segments)
                                       String strLayer = oSeg.Layer.Name;
                                       if ((strLayer == "3D Skizziergeometrie (ISO)")) //&& (oSeg.StartPoint.Y == oSeg.EndPoint.Y))
                                            bUseThis = true;
                          catch { }
                      if (bUseThis == true)
                          oCurve = Curve;
                          break;
                 if (oCurve == null)
                      return;
                 oStart = _oActiveSheet.CreateGeometryIntent(oCurve.StartPoint, Inventor.PointIntentEnum.kStartPointIntent);
                 oEnd = _oActiveSheet.CreateGeometryIntent(oCurve.EndPoint, Inventor.PointIntentEnum.kEndPointIntent);
                 double TextX = oCurve.MidPoint.X;
                 double TextY = oCurve.MidPoint.Y + 0.25;
                 try
                      //this one failed (oStart and oEnd are not Correct, but how can i fix this?
_oActiveSheet.DrawingDimensions.GeneralDimensions.AddLinear(oTG.CreatePoint2d(TextX, TextY),oStart, oEnd, Inventor.DimensionTypeEnum.kAlignedDimensionType, true, null, null);
                 catch { }
             catch{}
         catch{ }
         finally { }
Nobody, who know what to do? Or is it impossible?
AS
PS: we use Inventor in Version 2011 and 2012 soon
