Problem with dimension creation when drawing view has break out.
Hubert_Los
Hubert_Los
I have a simple code that creates the dimension of a drawing view when a curve is selected. I have a problem with the line from break out, the red line on the left. On the right everything looks ok. the GeometryIntent point is the same as in the drawing, but the dimension was created lower. Why?
Dim drawingDocument As DrawingDocument = ThisApplication.ActiveDocument
Dim sheet As Sheet = drawingDocument.ActiveSheet
Dim drawingCurveSegment As DrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select line")
Dim drawingCurve As DrawingCurve = drawingCurveSegment.Parent
Dim startPoint As Point2d = drawingCurve.StartPoint
Dim endPoint As Point2d = drawingCurve.EndPoint
Dim geometryIntent1 As GeometryIntent = sheet.CreateGeometryIntent(drawingCurve, startPoint)
Dim geometryIntent2 As GeometryIntent = sheet.CreateGeometryIntent(drawingCurve, endPoint)
Dim textPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(startPoint.X - 1, (startPoint.Y + endPoint.Y) / 2)
sheet.DrawingDimensions.GeneralDimensions.AddLinear(textPoint, geometryIntent1, geometryIntent2, DimensionTypeEnum.kVerticalDimensionType)
daltonNYAW9
The curve type is likely different so you will need to change the intent type. You can test it with this:
MessageBox.Show(drawingCurve.CurveType.ToString)
Hubert_Los
No, it is the same.
I re-set Intent1 and Intent2 in the dimension, after creation. And now it works
