Problem with ConvertToGeometry
Mr.Zähl6809
Mr.Zähl6809
Hello everyone,
I have installed the new Inventor version 2024.2. Now I have a problem with an iLogic rule. My rule places a text on a defined surface and converts the text to a text geometry with the command oSketchText.ConvertToGeometry("ISOCP").
This worked with Inventor version 2020 without any problems. With Inventor version 2024, I get an exception in line 59 after the second call of the Engraving rule: Wrong parameter. (Exception from HRESULT: 0x80070057 (E_INVALIDARG)) Any ideas or workarounds?
Sub Main
	Dim sText As String, iXPos As Integer
	sText = "<StyleOverride Font='ISOCPEUR' FontSize='0,45'>Test 1</StyleOverride>"
	Engraving("Deckplatte", "SchluesselschalterText1_1", sText, -50, 700)
	sText = "<StyleOverride Font='ISOCPEUR' FontSize='0,45'>Test 2</StyleOverride>"
	Engraving("Deckplatte", "SchluesselschalterText1_2", sText, 50, 700)
End Sub
Public Sub Engraving(sAssemblyName As String, sEngravingName As String, sEngravingText As String, xPos As Double, yPos As Double)
	'--- Focus auf AssemblyName z.Bsp. "Deckplatte" setzen
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim oOccs As ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
	Dim oOcc As ComponentOccurrence
	Dim oSubDoc As Document
	For Each oOcc In oOccs
	     If oOcc.Name = sAssemblyName Then
	          oSubDoc = oOcc.Definition.Document
	          Exit For
	Next
	If oSubDoc Is Nothing Then Exit Sub
	Dim oNamedEntities As NamedEntities = iLogicVb.Automation.GetNamedEntities(oSubDoc)
	Dim oDef As PartComponentDefinition = oSubDoc.ComponentDefinition
	Dim oFace As Face = oNamedEntities.FindEntity("ImprintFace")
    Dim InsPointX As Double = xPos / 10 'in cm
    Dim InsPointY As Double = yPos / 10 'in cm
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
  	Dim oPoint As Point2d = oTG.CreatePoint2d(InsPointX, InsPointY)
	Dim oSketchText As Inventor.TextBox
	Dim oSketch As PlanarSketch
	Dim oStyle As Inventor.TextStyle
	Dim i As Integer, bFound As Boolean
	'---Skitze auf die Fläche "ImprintFace" legen
	bFound = False
	For Each oSketch In oDef.Sketches
		If oSketch.Name = "Engraving_" & sEngravingName Then
			bFound=True
			Exit For
	Next
	If bFound =False Then
		oSketch = oDef.Sketches.Add(oFace)
	oSketch.Edit
    '---Textbox mit Formatierung erzeugen
	oSketchText = oSketch.TextBoxes.AddFitted(oPoint, sEngravingText)
	oSketch.ExitEdit
	oSubDoc.Close
End Sub
SBix26
Coding questions will get more attention in the Inventor Programming - iLogic, Macros, AddIns & Apprentice forum.
Sam B
Inventor Pro 2024.2 | Windows 11 Home 22H2
