Problem with bom part number row merge
I created a bom export rutine but when a virtual component is the same as a inserted standard part the rowmerge does not work. is there any solution to this.
see example picture in attachment.
adam.nagy
Autodesk Support
Autodesk Support
Can you do the same in the user interface? If no, then it may be a product limitation.
Might be worth asking on the product forum as well - if you haven't done it already.
Cheers,
Adam Nagy
Autodesk Platform Services
This was a "dummy me" error 😞 the part numbers were not the same. I got it all working :-).
