Problem related to rotation of an occurence
Message 1 of 14
Hi i tried rotate a particular occurence called cabin which is in a subassembly called my final crane assembly:1
when i tried to rotate the cabin , the whole crane is rotating. my code is given below. can any one try to help me out from this issue...Public Sub CreateProxies()
Dim oassDoc As AssemblyDocument
Set oassDoc = ThisApplication.ActiveDocument
Dim oasscompdef As AssemblyComponentDefinition
Set oasscompdef = oassDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim cabin As ComponentOccurrence
Dim oPartProxy As ComponentOccurrenceProxy
Set oOcc = oasscompdef.Occurrences.ItemByName("my final crane assembly:1")
Set cabin = oOcc.Definition.Occurrences.ItemByName("cabin:1")
Call oOcc.CreateGeometryProxy(cabin, oPartProxy)
Dim oHS1 As HighlightSet
Set oHS1 = oassDoc.HighlightSets.Add
oHS1.SetColor 255, 0, 0
oHS1.Clear
oHS1.AddItem oPartProxy
MsgBox "proxy is highlighted"
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Get the current matrix from the occurrence.
Dim oRotMat As Matrix
Set oRotMat = oOcc.Transformation
'Create a point based on the current position of the occurrence.
Dim oCenter As Point
Set oCenter = oTG.CreatePoint(oRotMat.Translation.x, oRotMat.Translation.y, oRotMat.Translation.z)
' Define the matrix that specifies the rotation about the Z axis and the center point.
' The angle is pi/2 or 90 degrees.
Dim dpi As Double
dpi = 1.74532925199432E-02
Dim i As Integer
For i = 1 To 5
Call oRotMat.SetToRotation(dpi, oTG.CreateVector(0, 0, 1), oCenter)
Dim oMat As Matrix
Set oMat = oOcc.Transformation
'Multiply the occurrence matrix by the rotation matrix.
Call oMat.MultiplyBy(oRotMat)
'Apply the new matrix back to the occurrence.
oOcc.Transformation = oMat
dpi = dpi + 1.74532925199432E-02
Next
End Sub
Replies (13)
Message 2 of 14
Hello bharathc85,
you can read the follow link.
http://modthemachine.typepad.com/my_weblog/2009/04/positioning-assembly-occurrences.html
There are good information about you want.
Bye
Luizoo from Brazil
Message 3 of 14
thanks Luizoo.. hope this will be helpful...good site.
Message 4 of 14
my problem is different, it doesnt provide any solution for me..
Message 5 of 14
You are applying the transform to the sub-assembly occurrence in this line
of code:
Shouldn't you apply it to the PartProxy occurrence?
Sanjay-
Message 6 of 14
hi if you don't mind will u plz tell clearly. iam attaching the model, in that the brown object on which some text is written is the cabin. when i try to rotate that entire crane is rotating.
Message 7 of 14
i tried to change to proxy , its showing the error as OVERFLOW
Message 8 of 14
Hello Bharathc85,
i was analyzing your code. Pay attention:
You took the complete Assembly with "oOcc" variable and then you applied a transform matrix on this variable.
You need to apply a transform matrix on the "cabin" object and do not on the "oOcc".
Did you understand me?
Bye
Message 9 of 14
Here is a fragment of code that we have used.
We selected some componentes inside one Assembly and then the macro move and rotate these componentes to the assembly origin.
Maybe is can help you.
'Variables Declarations
Dim oAssDoc As AssemblyDocument
Dim oAssDef As AssemblyComponentDefinition
Dim oAssOcc As ComponentOccurrence
Dim oTrans As TransientGeometry
Dim oWorkPlane As WorkPlane
Dim oMatrix As Matrix
Dim oPlane As Plane
Dim oWorldOrigin As Point
Dim oWorldXvector As UnitVector
Dim oWorldYvector As UnitVector
Dim oWorldZvector As UnitVector
'***Geting Assembly Coordinate System.
'Verifing if the active document is an Assembly Document
If ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
'Geting the active document if YES
Set oAssDoc = ThisApplication.ActiveDocument
Else
'Exiting if NOT
Exit Sub
'Geting active document XY plane
Set oWorkPlane = oAssDoc.ComponentDefinition.WorkPlanes(3)
'Geting XY plane Position
'A plane position is defined by Origin, X Vector and Y Vector
Call oWorkPlane.GetPosition(oWorldOrigin, oWorldXvector, oWorldYvector)
'Geting a Transient Plane Geometry abou XY plane
Set oPlane = oWorkPlane.Plane
'Geting the Z vector
Set oWorldZvector = oPlane.Normal
'Define Trasformation Matrix
Set oTrans = ThisApplication.TransientGeometry
Set oMatrix = oTrans.CreateMatrix
Call oMatrix.SetCoordinateSystem(oWorldOrigin, oWorldXvector.AsVector, oWorldYvector.AsVector, oWorldZvector.AsVector)
' Initialize flag.
bStillSelecting = True
' Create an InteractionEvents object.
Set oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
oInteractEvents.StatusBarText = "Select a component."
' Ensure interaction is enabled.
oInteractEvents.InteractionDisabled = False
' Set a reference to the select events.
Set oSelectEvents = oInteractEvents.SelectEvents
' Set the filter using the value passed in.
oSelectEvents.AddSelectionFilter kAssemblyOccurrenceFilter
' Start the InteractionEvents object.
oInteractEvents.Start
' Loop until a selection is made.
Do While bStillSelecting
DoEvents
Loop
' Get the selected item. If more than one thing was selected,
' just get the first item and ignore the rest.
Dim oSelectedEnts As ObjectsEnumerator
Set oSelectedEnts = oSelectEvents.SelectedEntities
'Moving and Rotating the Component
If oSelectedEnts.Count > 0 Then
For iNumber = 1 To oSelectedEnts.Count
oSelectedEnts.Item(iNumber).Transformation = oMatrix
oSelectedEnts.Item(iNumber).Grounded = True
'Set Pick = oSelectedEnts.Item(1)
Next
Else
'Set Pick = Nothing
' Stop the InteractionEvents object.
oInteractEvents.Stop
' Clean up.
Set oSelectEvents = Nothing
Set oInteractEvents = Nothing
End
Message 10 of 14
i tried that also , but the constraints are restricting it, as u can see in the attachment also, iam trying very hard, but not able to rotate . i tried without constarints transformation also its not giving desired motion.
is there any other way.
Message 11 of 14
thanks for this example. Edited by: bharathc85 on Sep 21, 2009 2:47 PM
Message 12 of 14
Hello again,
so, i do not know exactly the mates you have, but you can make an Angular Mate and then you can change the angle of it through Macro.
In this case, you do not need to use transformation matrix.
Bye.
Luizoo from Brazil
Message 13 of 14
Hi thats good suggestion, Iam about to post that , i tried to rotate through the angle constraint its rotating as i desired . thanks for u r timely suggestion.
Message 14 of 14
Ok, Goooood.
Luizoo from Brazil
