Problem is in the reflection data in the specification
vyivanchikov
vyivanchikov
Good day colleagues!
Faced such a problem in inventor 2020 with the latest update. windows 10 build 19031.
When working with the frame generator, as well as with parts built by hand, you must export the parameters (length, width).
The sizes exported are naturally fractional, 2 decimal places.
So, when you export the parameter, G_L and G_B, you can see how many decimal places(the number itself, for example 800.25 mm)
But for some reason this number is rounded to an integer. I force rounding to the desired value. Seems to be OK. Save. Close
Open the drawing, specification, and observe the old value, with rounding
Open the item, again, everything goes back to the original value with rounding.
Can update windows or inventor
Has anyone ever had one of these?
How to treat?
HideoYamada
It seems that there is no way to avoid auto updating.
You can make a new rounded parameter for just exporting.
(But this method is annoying...)
See also about the functions
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-EE98BCED-5623-4E3B-9E98-432C6738B081
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
vyivanchikov
it turns out that now it is necessary to edit the Content Сenter library?
HideoYamada
I thought the parameter must be added to the part manually one by one.
Your idea (customizing Content Center Library) is good!
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
vyivanchikov
Hello!
The problem was solved simply by reinstalling the Inventor system as a whole
Thank you for your feedback and help)
