Printing with VB .Net
GeorgK
Advisor Advisor
Message 1 of 8
GeorgK
Hello together,
is there a complete sample for printing on different printers, paper size, scale mode, sheets, orientation, color, line weights, preview and paper source?
Thank you very much
Georg
Replies (7)
Message 2 of 8
skyngu
no, there is not a complete sample.
Autodesk Inventor Professional 2019
Message 3 of 8
GeorgK
Do you have some examples?
Message 4 of 8
This code is used for printing to 3 different printers, please note that the identification of paper size and oreintation is done by checking the boarder size which I am using. change it accordingly.
 Private Sub oButtonAutoPrint_OnExecute(Context As Inventor.NameValueMap) Handles oButtonAutoPrint.OnExecute
            Try
                Dim oDoc As Inventor.DrawingDocument
                oDoc = m_inventorApplication.ActiveDocument
                Dim oSheet As Inventor.Sheet
                oSheet = oDoc.ActiveSheet
                Dim oPM As Inventor.PrintManager
                oPM = oDoc.PrintManager
                Dim strPrinter As String = Nothing
                If oSheet.Border.Name = "IP-A4R" Then
                    oPM.Printer = "HP LaserJet 1022"
                    oPM.ColorMode = PrintColorModeEnum.kPrintGrayScale
                    oPM.PaperSize = PaperSizeEnum.kPaperSizeA4
                    oPM.Orientation = PrintOrientationEnum.kLandscapeOrientation
                    oPM.NumberOfCopies = 1
                    oPM.scalemode = Inventor.PrintScaleModeEnum.kPrintBestFitScale
                    oPM.printrange = Inventor.PrintRangeEnum.kPrintCurrentSheet
                    oPM.RemoveLineWeights = True
                ElseIf oSheet.Border.Name = "IP-A4" Then
                    oPM.Orientation = PrintOrientationEnum.kPortraitOrientation
                ElseIf oSheet.Border.Name = "IP-A3" Then
                    oPM.Printer = "HP Officejet Pro K850 Series"
                    oPM.ColorMode = PrintColorModeEnum.kPrintColorPalette
                    oPM.PaperSize = PaperSizeEnum.kPaperSizeA3
                ElseIf oSheet.Border.Name = "IP-A2" Then
                    oPM.Printer = "HP Designjet 500 42+HPGL2 Card"
                    oPM.PaperSize = PaperSizeEnum.kPaperSizeA2
                    oPM.Rotate90Degrees = True
                ElseIf oSheet.Border.Name = "IP-A1" Then
                    oPM.PaperSize = PaperSizeEnum.kPaperSizeA1
                ElseIf oSheet.Border.Name = "IP-A0" Then
                    oPM.PaperSize = PaperSizeEnum.kPaperSizeA0
                oPM.SubmitPrint()
                    MsgBox("Please Load A2 Paper (Portrait) on " & strPrinter, MsgBoxStyle.Information, " Automated Printing")
                    MsgBox("Please Load A1 Paper (Portrait) on " & strPrinter, MsgBoxStyle.Information, " Automated Printing")
                    MsgBox("Please Load A0 Paper (Roll) on " & strPrinter, MsgBoxStyle.Information, " Automated Printing")
            Catch ex As Exception
                MsgBox(ex.Message)
            End Try
        End Sub
Message 5 of 8
GeorgK
Thank you very much for your example.
Message 6 of 8
j_kleijnjansY73VU
Hello
I try to put your code in VB but unfortunately I get an error message.
I can not find out what is wrong. Perhaps you can help me
Regards Jos
Message 7 of 8
WCrihfield
Hi @j_kleijnjansY73VU.  The error is saying that it does not recognize the "m_inventorApplication" variable you are trying to use.  That local variable is supposed to be 'declared' at the Class level, at same level as the Sub routine which you are trying to use that variable within, or at a higher level, so that you can access it from within all the Sub/Function routines defined within that Class.  It is supposed to represent the Inventor.Application object.  If you already have a local variable which represents an instance of the Inventor.Application object, but it is spelled differently, then use that variable there instead.
Also, when you know you are working with a DrawingDocument, instead of some other type of Inventor Document, then you could be working with the DrawingPrintManager type, instead of the regular PrintManager type.  The DrawingPrintManager is a type that is derived from the PrintManager type, and is obviously specific for drawings, and has a lot more properties and methods available to it, that are unique to drawings.
Wesley Crihfield
(Not an Autodesk Employee)
Message 8 of 8
j_kleijnjansY73VU
I'm going to try to solve this. I don't know much about programming myself.
Yes it worked👍 thanks
