Printing Different size sheets
Message 1 of 8
Hi Guys First time post in this group..
Im currently trying to create a macro to print and dxf automatically, which i have succefully done... well almost!
we have the instance where we have say a sheet 1 and a _LSR for flat pattern laser cutting drawings. Typically the Sheet 1 will be an A3 size drawing, and the laser will be anything up to A0. The problem i have is getting the sheets to print out in their own size, the macro i have grabs the first sheet size and sets it from there.
the dxf works great as it doesnt rely on paper sizes, but the PDF is an issue
Anyone got a clue if what im trying to do is possible?
Thanks in advance
Steve Oliver
Replies (7)
Message 2 of 8
I'm not very clear about the problem. Could you post the code you have to
illustrate?
Sanjay-
Message 3 of 8
Hi Sanjay apologies for not being clear!
the PDF code i have is:-
Sub PDF_uncontrolled()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oLayer As Layer
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Get the layer object that we want to use.
Set oLayer = oDrawDoc.StylesManager.Layers.Item("Uncontrolled")
oLayer.Visible = True
oDrawDoc.PrintManager.Printer = "PDFCreator"
oDrawDoc.PrintManager.NumberOfCopies = 1
oDrawDoc.PrintManager.PrintRange = kPrintAllSheets
oDrawDoc.PrintManager.Orientation = kLandscapeOrientation
oDrawDoc.PrintManager.Rotate90Degrees = False
oDrawDoc.PrintManager.PaperSize = kPaperSizeA3
oDrawDoc.PrintManager.SubmitPrint
oLayer.Visible = False
End Sub
There is also a borrowed and slightly modded code i got from here also that i was trying to do the same thing with, but ended up using it as a single sheet print for the odd size sheet.
Option Explicit
Private Function FindSheetSize(varSheet As Sheet) As PaperSizeEnum
Select Case varSheet.Size
Case kA4DrawingSheetSize
FindSheetSize = kPaperSizeA4
Case kA3DrawingSheetSize
FindSheetSize = kPaperSizeA3
Case kA2DrawingSheetSize
FindSheetSize = kPaperSizeA2
Case kA1DrawingSheetSize
FindSheetSize = kPaperSizeA1
Case kA0DrawingSheetSize
FindSheetSize = kPaperSizeA0
End Select
End Function
Public Sub PDFCurrentSheet()
Dim varDrawingDoc As DrawingDocument
Set varDrawingDoc = ThisApplication.ActiveDocument
Dim varPrintManager As DrawingPrintManager
Set varPrintManager = varDrawingDoc.PrintManager
Dim varSheet As Inventor.Sheet
Set varSheet = varDrawingDoc.ActiveSheet
' Declare and show the uncontrolled layer
Dim oLayer As Layer
Set oLayer = varDrawingDoc.StylesManager.Layers.Item("Uncontrolled")
With varPrintManager
.PaperSize = FindSheetSize(varSheet)
.PrintRange = kPrintCurrentSheet
.ScaleMode = kPrintFullScale
End With
If FindSheetSize(varSheet) = kPaperSizeA1 Then
varDrawingDoc.PrintManager.Rotate90Degrees = True
ElseIf FindSheetSize(varSheet) = kPaperSizeA0 Then
Else:
varDrawingDoc.PrintManager.Rotate90Degrees = False
varDrawingDoc.PrintManager.SubmitPrint
End Sub
So my end goal is to have a macro that prints all sheets in their respective sheet size. the problem i have is that most macros i have seen get the sheet size from the active sheet and the run the print routine..
what i need is a macro that can print all sheets in the correct size, in the current single PDF file rather than several PDF files appended with the sheet number.
im very new to this so apologies for the dodgy code.
im also thinking that this is an issue related more to the pdf printer than anything else!
Does that make more sense?
Steve Oliver
Message 4 of 8
I understand now. You have sheets of different sizes in your drawing and you
want to print them to the appropriate paper size to the same PDF. As far as
I know, this will not be possible. The only thing I could think of is to
experiment with the ScaleMode property to best fit the drawing to the
specified paper size, but this may not be acceptable if you always want full
scale drawings.
Sanjay-
Message 5 of 8
Thanks Sanjay
the more i thought about it the more i came to the conclusion that i was limited by the driver / print all sheets method.
i have a clunky workflow i can follow so i should be ok... not quite the one click that i was hoping tho!
be interested to hear if anyone else has a solution tho...
Steve Oliver
Message 6 of 8
oh Sanjay, anything is possible with computers! (well, almost anything)
Here is my printing macro, and no it doesn't print each page to the same pdf, but it will create a series of pdfs that you can then combine.
Public Sub PrintDrawingToPDF()
' set printer
Dim sPrinter As String
sPrinter = "Adobe PDF"
' get application
Dim oIVApp As Inventor.Application
Set oIVApp = GetInventor
If oIVApp Is Nothing Then Exit Sub
' get document
Set oDrawDoc = GetActiveDrawing
If oDrawDoc Is Nothing Then Exit Sub
' get print manager
Dim oPM As DrawingPrintManager
Set oPM = oDrawDoc.PrintManager
If Not DrawingCheckPrinter(oPM, sPrinter) Then
MsgBox "Printer " & sPrinter & " was not found", , "Error"
Exit Sub
' loop thru drawing, printing similar sheets together
Dim oSheet As Sheet
Dim oPaperSize As PaperSizeEnum
Dim oOrientation As PrintOrientationEnum
Dim bflag As Boolean
bflag = False
Dim iStart As Integer
Dim iEnd As Integer
Dim i As Integer
i = 1
While oDrawDoc.Sheets.Count >= i
' set size and orientation
Set oSheet = oDrawDoc.Sheets(i)
Let oPaperSize = DrawingGetPaperSizeFromSheet(oSheet)
Let oOrientation = DrawingGetPrintOrientationFromSheet(oSheet)
iStart = i
' find last consecutive sheet with same size and orientation
bflag = False
While oDrawDoc.Sheets.Count >= i And Not bflag
If oPaperSize = DrawingGetPaperSizeFromSheet(oSheet) And _
oOrientation = DrawingGetPrintOrientationFromSheet(oSheet) Then
iEnd = i
i = i + 1 ' increment counter
Else
bflag = True
Wend
' print the sheets
With oPM
.Printer = sPrinter
.AllColorsAsBlack = False
.ColorMode = kPrintColorPalette
.NumberOfCopies = 1
.Orientation = oOrientation
.PaperSize = oPaperSize
.TilingEnabled = False
.PrintRange = kPrintSheetRange
.SetSheetRange iStart, iEnd
.SubmitPrint
End With
Wend
End Sub
Public Function GetActiveDrawing() As DrawingDocument
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Set GetActiveDrawing = ThisApplication.ActiveDocument
Else
MsgBox "Must have a drawing active", vbOKOnly, "Error"
End Function
Public Function DrawingGetPaperSizeFromSheet(oSheet As Sheet) As PaperSizeEnum
Select Case oSheet.Size
Case kADrawingSheetSize
oPaperSize = kPaperSizeLetter
Case kBDrawingSheetSize
oPaperSize = kPaperSize11x17
Case kCDrawingSheetSize
oPaperSize = kPaperSizeCSheet
Case kDDrawingSheetSize
oPaperSize = kPaperSizeDSheet
Case kEDrawingSheetSize
oPaperSize = kPaperSizeESheet
Case kFDrawingSheetSize
MsgBox "Unknown paper size, print manually", , "Error"
Exit Function
oPaperSize = kPaperSizeA0
oPaperSize = kPaperSizeA1
oPaperSize = kPaperSizeA2
oPaperSize = kPaperSizeA3
oPaperSize = kPaperSizeA4
Case Else
oPaperSize = kPaperSizeDefault
End Select
Let DrawingGetPaperSizeFromSheet = oPaperSize
End Function
Public Function DrawingGetPrintOrientationFromSheet(oSheet As Sheet)
Select Case oSheet.Orientation
Case kLandscapePageOrientation
oOrientation = kLandscapeOrientation
Case kPortraitPageOrientation
oOrientation = kPortraitOrientation
Case Else
oOrientation = kDefaultOrientation
End Select
Let DrawingGetPrintOrientationFromSheet = oOrientation
End Function
Public Function DrawingCheckPrinter(oPM As PrintManager, sPrinter As String) As Boolean
On Error Resume Next
oPM.Printer = sPrinter
If Err Then
Err.Clear
DrawingCheckPrinter = False
Else
DrawingCheckPrinter = True
On Error GoTo 0
End Function
Public Function GetInventor(Optional bCreateApp As Boolean = True) As Inventor.Application
Set GetInventor = GetObject(, "Inventor.Application")
If Err Then
Err.Clear
If bCreateApp Then
' ask user to start Inventor
Dim iAns As Integer
iAns = MsgBox("Inventor is not currently running. Would you like to start the program?", vbYesNo)
If iAns = vbYes Then
Set GetInventor = CreateObject("Inventor.Application")
If Not GetInventor Is Nothing Then
GetInventor.visible = True
Else
Set GetInventor = Nothing
On Error GoTo 0
End Function
Message 7 of 8
Of course, Josh. It's the combining at the end part that I didn't think of.
Sanjay-
Message 8 of 8
yes it would be super nice if it was possible to do this via API (and it may be with an Add-in). The part I can't figure out is how to feed the names of the .pdf output to the printer (of course if you're printing to a "normal" printer this isn't a problem). There is an Adobe PDF API that can be called by Inventor, unfortunately there is a print dialog that pops up that I can't figure out how to access. Maybe if I was compiling an Add-in, there would be an event to catch, but I'm only using VBA...
