print to PDF with iLogic
Stöcker
Stöcker
we need 3of9 barcodes on our drawings and the built in pdf saver aswell as SmartInventor PDF Exporter wont save the barcode right.
So i wrote a simple iLogic rule which gets activated via a macro by the user.
oPrintMgr = ThisApplication.ActiveDocument.PrintManager
pdfname = ThisDoc.FileName(False)
filePath = ThisDoc.Path
oPrintMgr.Printer = "Microsoft Print to PDF"
oPrintMgr.ColorMode = kPrintGrayScale
oPrintMgr.Orientation = kLandscapeOrientation
oPrintMgr.Scalemode = kCustomScale
oPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
oPrintMgr.PaperSize = kPaperSizeA4
oPrintMgr.PrintToFile(filePath+"\"+pdfname+".pdf")
So far it works pretty good, except for the Colormode. It always prints the PDF file in Color.
Anything i am missing?
Thanks in advance.
P.S.: I cant use any other PDF Printer than Microsoft PDF to print here at work.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Stöcker,
Hoping that below iLogic code may help.
Dim doc = ThisDoc.Document
doc.SaveAs(filePath+"\"+pdfname+".pdf", True)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Stöcker
Hello Chandra,
as i wrote in my opening post, i cant use the save to pdf function because the 3of9 code is incorrect if i do so.
If i print to a PDF it works fine, except that it will print it in color and not black only.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Stöcker,
Can you please provide sample drawing file which contain 3of9 code to test? Please make sure that file is non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Stöcker
I cannot, sorry.
It is nothing special, just an additional field where the partnumber gets written in a 3of9 font like this *<PartNumber*.
When i save the drawing as a PDF the 3of9 Code in the PDF is wierdly spaced, not in the right text height etc. When i print directly from the .idw or print as a PDF it works perfectly fine.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Stöcker,
Try the suggestions in below forum discussion.
https://forums.autodesk.com/t5/inventor-forum/font-bar-code-dwg-to-pdf/td-p/5514508
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Stöcker
I dont get your response sorry.
I do exactly what is suggested in the post you linked. The only issue i am having is that i want to print the pdf in bw and not colored.
 Update:
I managed to get it to print the pdf in bw
I changed
oPrintMgr.ColorMode = PrintColorModeEnum.kPrintGrayScale
to
oPrintMgr.AllColorsAsBlack = True
and now it works.
