print plot A1 on Canon IPF820
^_^clovis^_^
^_^clovis^_^
Hello guys,
I've written a small VBA macro to print/plot our standard format A4..A0.
All formats are OK except A1.
rotate 90° works but the remaining settings don't work:
If oSheet.Height >= oSheet.Width Then
        oPM.Orientation = kPortraitOrientation
        Else
        oPM.Orientation = kLandscapeOrientation
Case "A1"
             oPM.Printer = "CanonIp820"
             oPM.Rotate90Degrees = True
             oPM.PaperSize = kPaperSizeA1
             oPM.ScaleMode = kPrintBestFitScale
Has someone also experienced this "bug" ?
Without macro I can plot/print all formats without any issue.
Thanks for any advice.
yvandelafontaine
Try using "14359" or "14360" (A1 oversize) instead of "kPaperSizeA1"
EX:
If oSheetSize = "A" Then
				Dim oPrintMgr As PrintManager
				oPrintMgr = ThisApplication.ActiveDocument.PrintManager
				sPrinterName = "Canon iR-ADV C5250 PCL6"
				oPrintMgr.Printer = sPrinterName
				'oPrintMgr.Orientation = kPortraitOrientation
				'oPrintMgr.Orientation = kLandscapeOrientation
				oPrintMgr.ScaleMode = kPrintBestFitScale
				oPrintMgr.Orientation = 13569
				oPrintMgr.PaperSize = 14353
				'oPrintMgr.PaperHeight = 11
				'oPrintMgr.PaperWidth = 8.5
				oPrintMgr.ColorMode = 13313
				oPrintMgr.NumberOfCopies = 1
				'oPrintMgr.ColorMode = kPrintGrayScale
				oPrintMgr.SubmitPrint
Else
Had the same problem until i used the value instead of the name.
if it solve your problem mark this as solved! i also like kudos... 😛
^_^clovis^_^
Salut Yvan
I've made the changes you that you indicated to no avail.
I've received a reaction from Canon. As they know nothing about Inventor-VBA macro,
They suggested I could plot to a file. Then I can check-compare the output between manually and programmatically created files.
Thanks for your reaction though
Yours
