Print part of a drawing
GeorgK
Advisor Advisor
Message 1 of 12
GeorgK
Hello together,
is there a possibility to print out a part of a drawing (1:1) for example to split it in 4 parts.
Thank you
Georg
Replies (11)
Message 2 of 12
GeorgK
Or to select the area like in Autocad.
Message 3 of 12
JamieVJohnson2
Inventor has limited options for printing, here are 3 ideas:
Use Model 1:1 with Tiled Printing turned on (it at least imitates what you drew).
Set the view screen to zoom to your area, then print with option Current Window.  You could play with browser or window size until you achieve the desired aspect ratio.
Change the actual sheet size to reduce and ignore all other entities.  This is the worst idea, because it would only print 1 not shiftable area, and you would have to shift ALL the contents of the document instead.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 4 of 12
GeorgK
@JamieVJohnson2
I thougt that I could program this function, which you described. I know the limitation of Inventor.
Message 5 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Unfortunately, Inventor won't support to print selected window. But, drawing need to adjust 1/4th part of original size. Then, print the drawing with "Current Window" option as shown below.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 6 of 12
GeorgK
@chandra.shekar.g
how could I calculate the distance? I tried it with the camera:
Public Sub Zoom_With_Camera()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim sheetWidth As Double
    sheetWidth = oSheet.Width
    Dim sheetHeight As Double
    sheetHeight = oSheet.Height
    Dim oCamera As Camera
    Set oCamera = ThisApplication.ActiveView.Camera
   Dim NewTargePnt As Point
   Set NewTargePnt = ThisApplication.TransientGeometry.CreatePoint((sheetWidth / 2 + 4), (sheetHeight / 2) - 4, 0)
   oCamera.Target = NewTargePnt
   Call oCamera.SetExtents(20, 20)
   oCamera.Apply
End Sub
The Sheet size is A0, A1, A2, A3, A4
Thank you Georg
Message 7 of 12
GeorgK
@chandra.shekar.g
Is there a formula to calculate the distance? Then I can print each part of the drawing.
Message 8 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Sorry for reply,
Hoping that solution provided in the below forum discussion may help.
https://forums.autodesk.com/t5/inventor-forum/zoom-extents-in-drawing-sheet/td-p/7985096
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 12
GeorgK
@chandra.shekar.g
The "current view" in the print dialog changes the printed area. Is there a relation or known value of the change?
Message 10 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Can you please demonstrate print issue with screen shots?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 12
GeorgK
@chandra.shekar.g
It looks different on the screen as on the paper. I don't know if it's possible to print it on the correct size.
Preview to printPreview to printCurrent windowCurrent windowDrawingDrawing
Message 12 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Sorry for late reply,
As Inventor API is not supporting to print of window selection, I suggest to try trial and error method until getting correct size.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
