Print Ilogic Rule
Print Ilogic Rule
donaldleigh
Print Ilogic Rule
donaldleigh
Hi all
I have the attached code for printing our drawings to paper.
It all works except its only printing the current open sheet and not the all of them. (within the same .idw)
Can anyone please help
Inventor 2014
Donald
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Hoping that below iLogic code would help to print all sheets in drawing.
'NumberCopies = InputBox("Enter Number of Copies", "Print Manager", "1")
Dim oDrawDoc As Inventor.Document
For Each oDrawDoc In ThisApplication.Documents.VisibleDocuments
	If (oDrawDoc.documenttype = kDrawingDocumentObject) Then 'Found a drawing
		Dim oSheet As Sheet
		For Each oSheet In oDrawDoc.Sheets
			oSheet.Activate
			Dim oPrintMgr As PrintManager
			oPrintMgr = oDrawDoc.PrintManager
			Dim sMyPrinter As String
			sMyPrinter = "\\AWE-SVR-01\KONICA MINOLTA C284 PCL"
oPrintMgr.Printer = sMyPrinter oPrintMgr.ColorMode = kPrintDefaultColorMode oPrintMgr.PrintRange = kPrintAllSheets oPrintMgr.Orientation = kLandscapeOrientation oPrintMgr.Scale = kPrintBestFitScale oPrintMgr.PaperSize = kPaperSizeB 'oPrintMgr.NumberOfCopies = NumberCopies 'MessageBox.Show("Printed " & NumberCopies, "Title") oPrintMgr.SubmitPrint Next End If Next
For reference, go through below forum discussion link.
https://forums.autodesk.com/t5/inventor-customization/print-only-a4-sheets-in-a-drawing/m-p/8117919
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
