Print API question
Print API question
Print API question
I've some problems with the control of the Windows
printer regarding Landscape and Portrait, the example below is a test of the of
DrawingPrintManager
property
Orientation, changing the orientation has no effect in the
code?
I may have misunderstood the possibility in the
DrawingPrintManager so
I would appreciate if anyone could clarify the usage of the
object.
title="DrawingPrintManager Object">
title="DrawingPrintManager Object">My goal is to make a "poor man"
PDF saver (with GhostScript) that generate a PDF file when the drawing is
saved.
title="DrawingPrintManager Object">-Patrick
Public Sub PrintTest()
    ' Set a reference to the print
manager object of the active document.
    ' This will fail if
a drawing document is not active.
    Dim oPrintMgr As
DrawingPrintManager
    Set oPrintMgr =
ThisApplication.ActiveDocument.PrintManager
    ' Set to print in Gray
    oPrintMgr.ColorMode =
kPrintGrayScale
    ' Set to
print one copy
    oPrintMgr.NumberOfCopies =
1
' Set the paper size.
    oPrintMgr.PaperSize =
kPaperSizeA4
    ' Set the Windows
printer name
    oPrintMgr.Printer = "EPSON Stylus Photo
750"
    ' Set to
print all sheets.
    oPrintMgr.PrintRange =
kPrintAllSheets
    ' Set to print full
scale.
    oPrintMgr.ScaleMode =
kPrintFullScale
' Set to print using portrait orientation.
oPrintMgr.Orientation = kPortraitOrientation
    ' Submit the print.
oPrintMgr.SubmitPrint
' Set to print using landscape orientation.
oPrintMgr.Orientation = kLandscapeOrientation
    ' Submit the print.
End Sub
Correction to the description:
.....Orientation, changing the orientation in the
code has no effect on the print?
Windows printer regarding Landscape and Portrait, the example below is a test
of the of
title="DrawingPrintManager Object">DrawingPrintManager property
code?
DrawingPrintManager
so I would appreciate if anyone could clarify the usage of the
object.
saved.
    ' This will fail
if a drawing document is not active.
    Dim oPrintMgr As
DrawingPrintManager
    Set oPrintMgr =
kPrintGrayScale
    ' Set to
print one copy
1
kPaperSizeA4
    ' Set the Windows
printer name
750"
    ' Set to
print all sheets.
kPrintAllSheets
    ' Set to print
full scale.
kPrintFullScale
    ' Submit the print.
    ' Submit the print.
End Sub
Patrick,
I've verified this problem and have filed a
defect.  Unfortunately it's too late to fix it for 5.3 SP2.
-Brian
test of the of
code?
DrawingPrintManager
object.
is saved.
print manager object of the active document.
    ' This
will fail if a drawing document is not active.
    Dim
oPrintMgr As DrawingPrintManager
    Set oPrintMgr =
kPrintGrayScale
    ' Set to
print one copy
1
kPaperSizeA4
    ' Set the Windows
printer name
750"
    ' Set to
print all sheets.
kPrintAllSheets
    ' Set to print
full scale.
kPrintFullScale
orientation.
    ' Submit the print.
    ' Submit the print.
End
Sub
Thanks for letting me know, Brian.
As a workaround bonus for me it has forced me to
learn all about DEVMODE to control all the printer properties and by doing this
I've made the adding to work.
Patrick,
-Brian
the code has no effect on the print?
test of the of
code?
the
title="DrawingPrintManager Object">DrawingPrintManager so I would
object.
drawing is saved.
    ' This
    Dim
    Set oPrintMgr =
kPrintGrayScale
    ' Set to
print one copy
1
kPaperSizeA4
    ' Set the
Windows printer name
Stylus Photo 750"
    ' Set to print all sheets.
oPrintMgr.PrintRange = kPrintAllSheets
    ' Set to print full scale.
kPrintFullScale
orientation.
    ' Submit the print.
    ' Submit the print.
End
Sub
