Prefill max/min value into InputBox
BRLMCHKD
BRLMCHKD
Hi Forum.
How to prefill two values (max/min) into InputBox with two parameters?
Attached screendump and part.
KR/ BRLMCHKD
dgreatice
I think you missing "&"
">=" & LDM_Min & " and <=" & LDM_Max
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
BRLMCHKD
Hi dgreatice.
Yes your tip works, THANK YOU 🙂
However there is now a little new problem occured,
my rule runs two times when activated, before updating my model.
But I'll do a new post to try to get answer on this.
KR
BRLMCHKD
