Possible to Change Line Weight of Mated Components using iLogic?
Message 1 of 1
I was wondering if it's possible to use iLogic to change the line weight of specific lines, like say a mating line?  We work with bonded components, and usually we make the bond lines thinner to better distinguish them from object lines.  This involves changing a drawing layer, set to the proper thickness, in an AutoCAD drawing.  Below is a crude example of what I'm referring to.
Replies (0)
