Position button on Open dropdown of QAT
Message 1 of 9
Is it possible to position a button on the Open dropdown of the Quick Access Toolbar?
The following works:
CommandControls AssemblyQATControls = oAssemblyRibbon.QuickAccessControls;
CommandControls PartQATControls = oPartRibbon.QuickAccessControls;
CommandControls ZeroQATControls = oZeroDocRibbon.QuickAccessControls;
AssemblyQATControls.AddButton(MyButton, truetrue"AppFileNewCmd");
PartQATControls.AddButton(MyButton, truetrue"AppFileNewCmd");
ZeroQATControls.AddButton(MyButton, truetrue"AppFileNewCmd");
but not this:
ZeroQATControls.AddButton(MyButton, truetrue"NewFileTemplate4");
Replies (8)
Message 2 of 9
Sorry, I mean the "New" dropdown.
Message 3 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
did you mean you can add your button to [New] menu if it is Assembly Ribbon or Part Ribbon, but cannot in Zero Ribbon?
Message 4 of 9
No, I am saying that I can add a button (to any ribbon) *after* the New dropdown, but I cannot add a button (to any ribbon) to the New dropdown itself (where my button is not visible until the New dropdown is opened).
Message 5 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
Hope the code below and the snapshot explains:
Sub test()
Dim ZeroQATControls As CommandControls
Set ZeroQATControls = ThisApplication.UserInterfaceManager.Ribbons("ZeroDoc").QuickAccessControls
Dim o As Object
Set o = ZeroQATControls(1)
o.ChildControls.AddButton ThisApplication.CommandManager.ControlDefinitions("AppFileSaveAsCmd")
End Sub
Message 6 of 9
Hi Xiaodong, can you give that to me in C#?  For some reason I can't convert it myself.
Message 7 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
Hi michael.collins2,
I am a little bit astonished it would be difficulty for you with these lines. Anyway, I took a tool to convert it and modify to meet the syntax of C#. Although it is not neccessary for these few lines, but just in case you have more codes need to be converted in the future:
http://www.developerfusion.com/tools/convert/vb-to-csharp/
public void test()
 CommandControls ZeroQATControls =   ThisApplication.UserInterfaceManager.Ribbons["ZeroDoc"].QuickAccessControls;
 object o = ZeroQATControls[1];
 o.ChildControls.AddButton(ThisApplication.CommandManager.ControlDefinitions["AppFileSaveAsCmd"]);
Message 8 of 9
Thank you.  I tried a different tool but the output of that tool would not compile.  I guess that tool was not familiar with the Inventor data model and got confused between what was a method and what was an array.
Let me try this code.  Thanks.
Message 9 of 9
Hi Xiaodong, yes that was a good start.  I just had to cast o as a CommandControl, and use my button.  Here is what I ended up with:
          CommandControl oA = AssemblyQATControls[1];
          oA.ChildControls.AddButton(dokument_Konfigurator);
          CommandControl oP = PartQATControls[1];
          oP.ChildControls.AddButton(dokument_Konfigurator);
          CommandControl oZ = ZeroQATControls[1];
          oZ.ChildControls.AddButton(dokument_Konfigurator);
