Popup with all Properties of selected component
inventor4578
Message 1 of 8
inventor4578
I try to make a iLogic code to get all informations about selected component in 3D.
This is my code, but not working good for the moment....
Any idea ?
Thanks!
Dim entity = ThisApplication.CommandManager.Pick(
  SelectionFilterEnum.kAssemblyOccurrenceFilter,
  "Select Component:")
If (Not entity Is Nothing) And _
(TypeOf entity Is ComponentOccurrence) Then
  Dim doc = entity.Definition.Document
  Dim propSet = doc.propertySets(
    "Summary Information")
  Dim msg As String
  For Each prop In propSet
    msg = msg + prop.Name + " = " + _
      prop.Value.ToString() + vbCrLf
  Next
    Dim propSet2 = doc.propertySets(
    "Document Summary Information")
  Dim msg2 As String
    msg2 = msg2 + prop.Name + " = " + _
  Next
     Dim propSet3 = doc.propertySets(
    "Design Tracking Properties")
  Dim msg3 As String
    msg3 = msg3 + prop.Name + " = " + _
  Next
       Dim propSet4 = doc.propertySets(
    "User Defined Properties")
  Dim msg4 As String
    msg4 = msg4 + prop.Name + " = " + _
  Next
    MessageBox.Show(msg + msg2 + msg3 + msg4, "iProperties")
Replies (7)
Message 2 of 8
Michael.Navara
You can see my opensource project on GitHub. You can modify it for your needs.
https://github.com/CADstudioCZ/Autodesk-Inventor
Message 3 of 8
inventor4578
Thank for you reply.
I have 2017
Message 4 of 8
Michael.Navara
You can download the project, replace reference to 2017 API, modify displayed properties and compile it. For compiling you can use VS Community Edition (free for OpenSource projects). I hope the the code doesn't use anything special from 2018 API.
Message 5 of 8
inventor4578
I have to try, thank you!
Message 6 of 8
J-Camper
Using Property.Value fails on Thumbnails, Dates, and boolean properties when converting to string.  Try using Property.Expression like this:
Dim PickCO As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Component")
If IsNothing(PickCO) Then Exit Sub ' If nothing gets selected then we're done
Dim PropertyMessage As String
For Each ps As PropertySet In PickCO.Definition.Document.PropertySets
	For Each prop As Inventor.Property In ps
		PropertyMessage += prop.Name & " = " & prop.Expression & vbCrLf
	Next
Next
MessageBox.Show(PropertyMessage, "Properties for " & PickCO.Name)
Let me know if you have any questions, or if this is not working as intended
Message 7 of 8
inventor4578
It is working good ! Thanks.
Is it possible to filter the results to see only the properties which has values? (and not see the properties which are empty)
Regards.
Message 8 of 8
J-Camper
This would filter out blank properties:
		If IsNothing(prop.Expression) Then Continue For
	Next
Next
Thumbnails and Part Icon come in as (NULL) and some properties may return 0's.  If you want those filtered out you need more filters.
Let me know if you have any questions, or if this is not working as intended.
