Plotting individual idw sheets from Vault to PDFs
Greetings all,
I would like to use the plot function to generate 3 individual PDFs from a 3-sheet idw in Vault.
Requirements:
1. Each PDF needs to be named after a certain field that is already populated in iProperties
2. All PDFs need to be output to a fixed folder in Vault
I have tried some iLogic codes and indeed it is possible to do that from within Inventor.  But should we need to print a large number of idws that will be a nightmare for me.
Any suggestion will be much appreciated.
Thanks in advance.
H.S.
PDS 2013
Vault Collaboration 2013
xiaodong_liang
Autodesk Support
Autodesk Support
Although I'd suggest moving this post to Vault forum, probably your questions have been answered in this AU class:
PDF, Email Notification, Print, and More with Autodesk® Vault Job Processor via powerJobs
http://au.autodesk.com/?nd=class&session_id=10330
