Please tell me how to make tab countsink visible in a drawing.
tkddud711
tkddud711
hello.
I posted the same content a year ago, but didn't get an answer.
I would like to write ilogic on the topic below.
If you model a tab as shown below, a tab is created with countsink.
If you draw M3,M4,M5,M6,M8,M10,M12, you will draw circles of Φ3,Φ4,Φ5,Φ6,Φ8,Φ10,Φ12 in the plan view.
I would like to hide the countsink circle drawn on the floor plan.
If the countsink cannot be hidden in the drawing when creating a tab, is there an ilogic that allows you to enter the size of the circle in the drawing and then select it?
Michael.Navara
You can try following code. It works only for first drawing view on active sheet, but it can be modified easily.
Sub Main()
    Dim drawing As DrawingDocument = ThisDoc.Document
    Dim drawingView As DrawingView = drawing.ActiveSheet.DrawingViews(1)
    Dim part As PartDocument = drawingView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim partDef As PartComponentDefinition = part.ComponentDefinition
    For Each holeFeature As HoleFeature In partDef.Features.HoleFeatures
        If holeFeature.HoleType <> HoleTypeEnum.kCounterSinkHole Then Continue For
        'Get the biggest circles of holeFeature in drawing view
        Dim biggestCircles As New List(Of DrawingCurveSegment)
        Dim biggestCircleRadius As Double = 0
        Dim holeDrawingCurves = drawingView.DrawingCurves(holeFeature)
        For Each holeDrawingCurve As DrawingCurve In holeDrawingCurves
            For Each drawingCurveSegment As DrawingCurveSegment In holeDrawingCurve.Segments
                Dim circle2d = TryCast(drawingCurveSegment.Geometry, Circle2d)
                If circle2d Is Nothing Then Exit For
                If circle2d.Radius > biggestCircleRadius Then
                    biggestCircles.Clear()
                    biggestCircleRadius = circle2d.Radius
                    biggestCircles.Add(drawingCurveSegment)
                ElseIf circle2d.Radius = biggestCircleRadius Then
            Next
        Next
        'Hide
        For Each biggestCircle As DrawingCurveSegment In biggestCircles
            biggestCircle.Visible = False
        Next
    Next
End Sub
tkddud711
thank you for the reply.
It works fine, but
Tabs using the pattern function are not applied.
I want to apply it to patterned tabs as well.
I want to select a view and apply the function.
Is it possible?
tkddud711
hello? Mr. Michael Navara.
In response to an inquiry from ilogic, a rule was created to hide the tab's countsink circle in the drawing, and there was a request.
I included a link to the file in the post I posted, but I also want to hide the circle in the tabs of the square pattern, circular pattern, and linked pattern.
And I want to select a view in the drawing.
Is it possible?
