PLEASE CHECK THIS DRAWING CODE. (MODIFYING SHEET NAME iLOGIC)
youneedtodonow
youneedtodonow
Here's an iLogic code that modifying sheet name automatically "<Part Number> <Stock Number>".
For example, Part number is "BS100" , Stock Number is "Shaft" then sheet name changed as BS100 Shaft.
This is my code below. There's an error but I couldn't check it and fix it.
Sub Main()
    ModifySheetName()
End Sub
Sub ModifySheetName()
    ' Get the active drawing document.
    Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
    ' Check if it's a drawing document.
    If oDrawDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
        MsgBox("This rule is intended to be used with drawing documents only.", MsgBoxStyle.Information)
        Exit Sub
    ' Get the part number and stock number from iProperties.
    Dim partNumber As String = iProperties.Value("Project", "Part Number")
    Dim stockNumber As String = iProperties.Value("Project", "Stock Number")
    ' Modify the sheet name.
    For Each oSheet As Sheet In oDrawDoc.Sheets
        If oSheet.SheetType = DrawingSheetTypeEnum.kSheetTypeDrawing Then
            oSheet.Name = partNumber & " " & stockNumber
    Next
    MsgBox("Sheet names have been modified.", MsgBoxStyle.Information)
End Sub
' Call the subroutine to modify sheet names.
Main()
Please check it and let me know how to do.
Thank you all.
Michael.Navara
Here is fixed version
  • Function Main() is called automatically by iLogic. iLogic is not a scripting language like JavaScript.
  • I don't know where you get DrawingSheetTypeEnum, but it is not defined in Inventor API
Sub Main()
    ModifySheetName()
End Sub
        Exit Sub
        'If oSheet.SheetType = DrawingSheetTypeEnum.kSheetTypeDrawing Then ' THIS IS NOT DEFINED
        'End If
    Next
End Sub
'Main() ' iLogic IS NOT A SCRIPTING LANGUAGE. YOU DON'T NEED TO CALL MAIN FUNCTION IT IS CALLED AUTOMATICALLY
MartinPapez
Hi  @Michael.Navara and @youneedtodonow,
that code works, but rename all the sheets with the same name.  In case that every sheet target different model, can be used something like the code below. Unluckily I am have not find out how to reach IProperties for the targeted models, so I just used the name of the model. Maybe You can take it further.
Sub Main()
    ModifySheetName()
End Sub
        Exit Sub
		oSheet.Activate()
		Dim oView As DrawingView
		oView = oSheet.DrawingViews(1)
		Dim viewModelDoc = ActiveSheet.View(oView.Name).ModelDocument
	'Doesn't work.
	'Dim partNumber As String = iProperties.Value(viewModelDoc, "Project", "Part Number")
	'Dim stockNumber As String = iProperties.Value(viewModelDoc, "Project", "Stock Number")
     'oSheet.Name = partNumber & " " & stockNumber
	 oSheet.Name = viewModelDoc.DisplayName.Remove(viewModelDoc.DisplayName.LastIndexOf("."))
    Next
End Sub
FINET_Laurent
Hi @MartinPapez,
Maybe somehting linke this ?
Sub main
        Exit Sub
		oSheet.Activate()
		Dim viewModelDoc As Inventor.Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
		Dim propertyset As Inventor.PropertySet = viewModelDoc.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")
		Dim partNumber As String = propertyset.Item("Part Number").Value.ToString
		Dim stockNumber As String =  propertyset.Item("Stock Number").Value.ToString
	 	'oSheet.Name = viewModelDoc.DisplayName.Remove(viewModelDoc.DisplayName.LastIndexOf("."))
    Next
End Sub
The commented line works too.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
MartinPapez
Hi @FINET_Laurent ,
great! I did not realized I can go throw Api, I was hopelessly searching in iLogic.
