Placing vertical drawing dimensions does not allow for dimension text placement on the vertical drawing axis
harvey_craig2RCUH
harvey_craig2RCUH
In my manage dimensions I I have placed this dimension using this line:
Dim CollarDia = genDims.AddLinear("CollarDia", ThisDrawing.Geometry.Point2d(CollarDia_X_Pos, 0.5), CollarDia1, CollarDia2,,,False)
 It is placed centrally like this as my y axis is set to 0.5:
I would like the text to be placed below the drawing like so:
I have tried changing the 0.5 to -0.1 and it has no effect, the dimension just remains in the middle. What can I do?
Harvey
Curtis_Waguespack
@harvey_craig2RCUH
I think the results you are seeing are due to this setting
You can turn it off in the settings, but you can't be sure that if another user runs your code on their machine, that it will be off.
So you can use something like this as part of your dimensioning code, to turn it off and then back on again:
'turn off centerdimensiontext setting, and then set it back to what the user had already set
oCurrentValue = ThisApplication.DrawingOptions.CenterDimensionText
ThisApplication.DrawingOptions.CenterDimensionText = False
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim VIEW1 = Sheet_1.DrawingViews.ItemByName("VIEW1")
Dim Face0 = VIEW1.GetIntent("Face0")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
Dim linDim1 = genDims.AddLinear("Dimension 1", VIEW1.SheetPoint(0.5, 1.1), Face0)
Dim Face2 = VIEW1.GetIntent("Face2")
Dim Face1 = VIEW1.GetIntent("Face1")
Dim linDim2 = genDims.AddLinear("Dimension 1", VIEW1.SheetPoint(1.25, 1.3), Face1, Face2)
ThisApplication.DrawingOptions.CenterDimensionText = oCurrentValue
harvey_craig2RCUH
Hi Curtis,
Works perfectly!
Harvey
