Placing iParts into an assembly with iLogic
medwardsNKCFQ
medwardsNKCFQ
I'm trying to automate nesting several hundred rectangular sheet metal plaques with sequential ID numbers.
The parts are fairly simple just a rectangle, rounded corners, 2 mounting holes, and text such as "AA PRODU 999".
I've successfully setup an iPart with all the required text variations being read from a spreadsheet.
What I want to do now is iteratively nest each variant of the iPart into an assembly in a grid layout.
I need help with using iLogic to place a specific variant of an iPart into an assembly at some specified location.
I'm new to iLogic, but have done some coding in Python, C# and Arduino/C in the past, so any help is appreciated.
medwardsNKCFQ
For anyone with a similar problem I figured out a solution, may not be the most efficient or user friendly, but it works for me:
'import parts folder as string EDIT ME!
Dim partsFolder As String = "R:\Industrial Engineering\A-ME\CAD\Dolly plaques v2"
'define number of plaques EDIT ME! (could be improved by reading this value from the selected part?)
Dim numOfPlaques As Integer = 500
'define size of plaque and spacing of laser EDIT ME!
Dim plaqueLength As Integer = 280
Dim plaqueWidth As Integer = 40
Dim laserClearance As Integer = 5
'define size of sheet for nesting EDIT ME!
Dim sheetLength As Integer = 2440
Dim sheetWidth As Integer = 1220
'define x y location variables
Dim xLocation As Integer = 0
Dim yLocation As Integer = 0
Dim sheetNum As Integer = 0
'main loop for number of plaques
Dim i As Integer = 0
While i < numOfPlaques
	i += 1
	'debugging window text
	'Dim txt As String = String.Format("X= {0}   Y= {1}",xLocation,yLocation)
	'MessageBox.Show(txt, "Part placed:")
	'set name and pos for adding component
	Dim name As String = String.Format("Plaque-{0}",i)
	Dim pos = ThisDoc.Geometry.Point(xLocation,0,yLocation)
	'add Component dolley plaques v2.ipt
	Dim componentPlaque = Components.AddiPart(name, partsFolder & "\Dolley plaques v2.ipt", row := i, position :=pos, grounded := True, visible := True, appearance := Nothing)
	'increment collumn
	xLocation += plaqueLength + laserClearance
	'increment row once collumns full
	If xLocation >= sheetLength - plaqueLength + ((sheetLength + plaqueLength) * sheetNum)
		'increment row
		yLocation += plaqueWidth + laserClearance
		'go back to bottom left corner of current sheet
		xLocation = 0 + ((sheetLength + plaqueLength) * sheetNum)
	If yLocation >= sheetWidth - plaqueWidth
		'this loop getting entered every collumn after first sheet
		'increment sheet number
		sheetNum += 1
		'go to bottom left corner of next sheet
		yLocation = 0
End While
