placing and constraining an item with iLogic
Good Day,
i was wondering if there was a way to place a component into an assembly and constrain it purely with ilogic, without any human interaction?  and if so how?
Thanks in advance 🙂
JelteDeJong
That is possible. Adding a part to a assembly is not a problem. see this rule:
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim matrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
Dim occurrence As ComponentOccurrence = oDoc.ComponentDefinition.Occurrences.Add("C:\temp\flange.ipt", matrix)
Constraining is also possible but is much more dificult. you can have a look at the help files. in the help files there are also examples
Jelte de Jong
Blog: hjalte.nl - github.com
Yijiang.Cai
@Anonymous , If you are using inventor 2019/2020, you could easily get the code samples on placing & constraining a components. Please see the image below. It should work for you.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Thank you so much!
Your solution worked perfectly for placing the component.
This example worked perfectly for placing a component into the top level of a model.
Is there way to place a component into a sub assembly where the rule is run?
Yijiang.Cai
You could use the code lines below -
Dim oDef As ComponentDefinition
oDef = oDoc.ComponentDefinition.Occurrences(1).Definition '1: we use the first sub-assembly to add the component, and you could pick the right one
odef.Occurrences.Add("C:\temp\part1.ipt", matrix)
River Cai
Autodesk, Inc.
Thank you for your reply, but is there a way to go directly to the sub assembly by name?
