Placing a SurfaceTexture Symbol with iLogic
harvey_craig2RCUH
harvey_craig2RCUH
I'm very close with this one, so this should be easy...
I wish to place a surface texture symbol on a geometry intent. I have managed to achieve this, but I can't find where to adjust the A' property. I need A' = 1.6 in this instance. This is the rule I have written:
'Document setup.
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView = ThisDoc.Document.Sheets.Item(1).DrawingViews.Item(1)
Dim viewname As String = ThisDoc.Document.Sheets.Item(1).DrawingViews.Item(1).Name 'get view name
Dim MainSheet = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim VIEW1 = MainSheet.DrawingViews.ItemByName(viewname)
'Get Intent.
Dim SealPoint2 As GeometryIntent = VIEW1.GetIntent("SealFace", PointIntentEnum.kMidPointIntent, nearPoint := VIEW1.SheetPoint(0, 1))
'Add it to collection as required by SurfaceTextureSymbol definition.
Dim mySurfaceTextureCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
mySurfaceTextureCollection.Add(SealPoint2)
'Setting up symbol and placing it.
Dim mySymbolDef As SurfaceTextureSymbolDefinition = oSheet.SurfaceTextureSymbols.CreateDefinition
mySymbolDef.SurfaceTextureType = kMaterialRemovalRequiredSurfaceType
Dim oSymbol As SurfaceTextureSymbol = oSheet.SurfaceTextureSymbols.AddByDefinition(mySurfaceTextureCollection, mySymbolDef)
 When you run it works:
I just require A' = 1.6 on it. I've attached the files.
Harvey
HermJan.Otterman
Hello Harvey,
add one line:
oSymbol.MaximumRoughness = "1.6"
 here are some other properties:
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Stephane_Hemberger
Thanks to your posts,
I was able to represent the surface texture symbol on the desired surface in the desired view of my drawing.
However, now when I try to add the A´ roughness value to the symbol or place the symbol in a specific location using the following code:
oSymbol.MaximumRoughness = ("0.8")
oSymbol.Position = textPoint
(where textPoint is a defined 2D point that’s positioned in the view and also used in other parts of the code),
it seems as if these two lines are ignored/not applied and I don’t receive any error message.
Does anyone have any idea how to resolve this?
Thank you in advance for any suggestions.
Best regards,
Stéphane Hemberger
HermJan.Otterman
hi,
in Harvey's code there is a line: mySurfaceTextureCollection.Add(SealPoint2), this should be the lastpoint in the list.
before this line add one or more of these lines:
mySurfaceTextureCollection.Add(ThisApplication.TransientGeometry.CreatePoint2d(10, 10))
where 10,10 is a coordinate in cm
Herm Jan
