Place iLogic Component Naming Option
Chirpyboy2060647
Chirpyboy2060647
Hi All,
So I have a bunch iLogic parts I've made and stuck at figuring out how to make it so I can name them during the 'Place iLogic Component' when placing in an Assembly. Is it something I need to add to the original part file? Currently it comes in like this
Counter-01
Counter-02
I'd like to be able to add either a prefix/suffix as needed to them
Thanks!
A.Acheson
As far as I am aware you cannot rename these before initial save. The place ilogic components function has its own internal process for naming which cannot be interrupted. So any renaming needs to occur after initial save in your assembly likely with a manually run code.
Regards
Alan
Chirpyboy2060647
Yeah after doing some more digging thats what im figured. Thats alright I can just use a rename code and replace part after.
Appreciate it!
