Picking up the solid volume by name
manu.marjanen
manu.marjanen
How do i get only "solid3" volume, by using iLogic?
Michael.Navara
You can read volume of all individual bodies, or one body accessed by its index (order) or its name
Dim part As PartDocument = ThisDoc.Document
'Get volume of individual bodies
Dim precisionPercent As Double = 0.01
For Each oBody As SurfaceBody In part.ComponentDefinition.SurfaceBodies
    Logger.Debug(String.Format("{0}{2}{1}", oBody.Name, oBody.Volume(precisionPercent), vbTab))
Next
'Get volume for individual body by its name
Dim bodyName As String = part.ComponentDefinition.SurfaceBodies(1).Name
Dim bodyByName As SurfaceBody = part.ComponentDefinition.SurfaceBodies.OfType(Of SurfaceBody).FirstOrDefault(Function(b) b.Name = bodyName)
If bodyByName Is Nothing Then
    Logger.Warn("Body not found")
Else
    Logger.Info(bodyByName.Volume(precisionPercent))
manu.marjanen
manu.marjanen
Can the "solid3" volume data be transferred to the parameter table?
Michael.Navara
Dim bodyName As String = "Solid3"
Dim solidVolume As Double = 0
Else
	solidVolume = bodyByName.Volume(precisionPercent)
    Logger.Info(solidVolume)
solidVolume *= 1000 'Convert [cm3] to [dm3]([l])
Parameter("Solid3_Volume") = solidVolume
cookie
Great routine @Michael.Navara , works a treat.
Now to work out how to run the routine whenever a change occurs on the part
