Persistent Face Reference Key for Sat Export
Hi Sanjay, Brian,
I have a third party application that I need to dump a sat file for.
However I also need to Identify a key model face for the app.
Is there a way to permenently mark a face that would be embedded in the sat?
Something on the order of giving the selected face a Name.
Cheers,
Tom,
There currently isn't a way to assign custom attributes to entities that
will show up in the exported SAT file. The API provides a way to export to
SAT with 'Transient Keys' attached to entities (see sample code below).
These transient keys are accessed using the TransientKey property on the
entities. See if you can leverage that in any way.
Sub OutputSAT()
Dim odoc As PartDocument
Set odoc = ThisApplication.ActiveDocument
Dim oSurfaceBody As SurfaceBody
Set oSurfaceBody = odoc.ComponentDefinition.SurfaceBodies(1)
Call oSurfaceBody.DataIO.WriteDataToFile("ACIS SAT with TransientKeys",
"c:\temp\testblock.sat")
End Sub
Sanjay-
wrote in message news:[email protected]...
Hi Sanjay, Brian,
Cheers,
Thanks Sanjay,
I worked something out involving a loose surface.
