PDF Addin
PDF Addin
A.WagnerKWWFA
PDF Addin
A.WagnerKWWFA
Hello
i using vba to export a drawing as pdf document.
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Is there a way to control the "show in viewer" option?
I mean opening after creating.
Or is there a *.ini file or reg entry where I can change (deactivate) it?
regards Andreas
jjstr8
There a value in the Options NameValueMap called "Launch_Viewer".  It doesn't seem to care what the value is in Inventor 2019.  If that's still the case in newer versions, the only option is to uncheck the "Display Published File in Viewer" box on the PDF export option dialog box.
