Pattern with assemblies view problem
When i make a pattern with 4 assemblies all these assemblies are the default view. But when i raise the pattern number to 5 the assembly that is new is on view master.
Is it possible to set all the assemblies within this pattern to the same view (default)? I tried somthing but it doesnt work.
Dim asmDef = ThisDoc.Document.ComponentDefinition
Dim compPattern As OccurrencePattern
Dim compObj As ComponentOccurrence
compPattern = asmDef.OccurrencePatterns("Pattern - Clamp plates") 'Pattern name
For Each obj As Object In compPattern.ParentComponents
	obj.SetDesignViewRepresentation("Default", , True) 'View Default associative
Next
rjay75
Try
obj.SetDesignViewRepresentation("Default", Nothing, True) 'View Default associative
Sorry for my late response & thank you for the help!
I tried adjusting this but still my views in the pattern are set to master.
Next
It's really frustrating. There are alot of invisible parts that suddenly get visible, and that not good.
What can i do?
rjay75
Try this, (I can't test it at the moment but I think its what is happening.)
It looks like you're only chaning the repesentation on the originating components but not the newly add ones.
Next
Instead try this one. This will go over all elements (old and new).
For Each element As OccurrencePatternElement in compPattern.OccurrencePatternElements
For Each obj As Object In element.Occurrences obj.SetDesignViewRepresentation("Default", Nothing, True) 'View Default associative Next
Next
