Pattern in iCopy template
kresh.bell
kresh.bell
I have iCopy template assembly.
The layout part has parameters that were transferred to the template assembly using the iCopy Author tool.
I am interested in how I can use transferred parameter qty for eg Pattern feature
If I link parameters from Layout part,
a problem appears when editing using iCopy: "Cannot edit this iCopy feature because of the template assembly is changed"
Does anyone have an idea for this problem?
kresh.bell
I've tried all possibilities and it's definitely a Pattern problem.
The pattern somehow causes the "structure of the template assembly is changed".
I can't find a solution for this problem.
Does anyone have an idea how to enable pattern feature in the iCopy template assembly?
Is it maybe an Inventor bug?
