Path of the file without the first folder
eladm
Message 1 of 28
eladm
Hello
Can I get help to get a ilogic rule of the file path without the first folder
C:\Work\AAAAA\BBBB
I want to get AAAA\BBBB
to write it in a drawing , to new template and also to old drawings
regards
Replies (27)
Message 21 of 28
TechInventor20
I think that is possible but that is loads of work for just a position of something that nobody would ever change.
Message 22 of 28
eladm
Can you write this text to iproperties like in the beginning ?
Message 23 of 28
TechInventor20
Dim oApp = ThisApplication
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
For Each oSheet In oDrawingDoc.Sheets
For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes
oGeneralNote.Delete
Next
Next
	oViews = oSheet.DrawingViews
	Dim oView As DrawingView
	For Each oView In oViews
		Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
		Dim oFullFilePath As String = oModelDoc.FullFileName
		'MsgBox(oModelDoc.FullFileName)
		Dim Input As String = oFullFilePath
		Dim folders = Input.Split("\").Skip(5)
		Dim newPath = String.Join("\", folders)
		'MsgBox(newPath)
    	' Set a reference to the TransientGeometry on active sheet.
    	Dim oTG As TransientGeometry
    	oTG = oApp.TransientGeometry
		oBorder = oSheet.Border
		Dim oNewPosition As Point2d
		oPlaceX = oBorder.RangeBox.MinPoint.X + 0.1
		oPlaceY = oBorder.RangeBox.MinPoint.Y + 0.25
        'Set reference to the new required position taken and create new 2d point
        oNewPosition = oTG.CreatePoint2d(oPlaceX,oPlaceY)
'		oSheet.DrawingNotes.GeneralNotes.AddFitted(ThisApplication.TransientGeometry.CreatePoint2d(DrawingView.position.x - DrawingView.width / 2, DrawingView.position.y - DrawingView.height / 2 - 1), newPath)
'		oSheet.DrawingNotes.GeneralNotes.AddFitted(oNewPosition,newPath)
		iProperties.Value("Custom", "05-Opmerking") = newPath
	Next
Next
Message 24 of 28
eladm
nothing happened
Message 25 of 28
TechInventor20
The part in green is a iproperty, you just have to change it to the property you wan't
Message 26 of 28
eladm
the ipro. is OK - the name not important
I also tried to other field
but it empty
Message 27 of 28
TechInventor20
I don't know what is wrong or how to implement it in the way you wan't it. I think that it is impossible to get it in the title blocks.
Message 28 of 28
Michael.Navara
If you want to have this information inside the title block, you have following possibilities.
  1. You can create TextBox as "prompt entry" and set its value. It is possible to do it programmatically. See this and this.
  2. You can create text box in title block definition referenced to drawing iProperty, but in this case you have the same value on all sheets.
  3. You can create text box in title block definition referenced to model iProperty, in this case you can have different values on each sheet. It depends on the first model on the sheet. And you need to update this iProperty in the model (not in drawing).
You can't use fixed text, because in this case you need to modify the title block definition. And this definition is the same for all sheets (usually for all drawing documents). Create new title block definition for each sheet is not good idea.
