Path of external iLogic rule
pavol_krasnansky
pavol_krasnansky
Hello
How do I get path of external iLogic rule? I want to use this path in external rule. I search something similar like "ThisDoc.Path" for Inventor dokument.
Thank you
Darkforce_the_ilogic_guy
what info are you looking for ? what do you need it for ?
JelteDeJong
here some code to get the directories with the external rules. maby it helps.
Dim iLogicAddinId As String = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"
Dim iLogicAddIn As Inventor.ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById(iLogicAddinId)
Dim iLogicAuto As Object = iLogicAddIn.Automation
Dim i As Integer = 1
If (iLogicAuto IsNot Nothing) Then
    For Each directory In iLogicAuto.FileOptions.ExternalRuleDirectories
		MsgBox(directory)
    Next
Jelte de Jong
Blog: hjalte.nl - github.com
