pass a variable to a form
If i run an Ilogic script, that calls a form, is it possible to pass a variable to that form without having to save it into the parameters?
for example if i have a form with a simple text label, can I call the form from Ilogic and pass a variable that is then loaded into the textlabel?
something like: SyntaxEditor Code Snippet
iLogicForm.ShowGlobal("MyForm",FormMode.Modal, Text1 = "hello world")
or a url to a image box.. so far i was only able to assign a variable from the parameters of the currently open file, but i do not want to save "hello world" or the url of a image for a picture box in the model parameters.
Hi @Anonymous,
are you creating an iLogic form from within Inventor or do you want to pass that value to an external/stand-alone application?
