Partslist automation
18154093
18154093
Hi all
I'm building a tool for partslist, but i get a problem about put 3 partslists for each model in a sheet drawing
Anyones has idea for this
Thanks all
WCrihfield
Hi @18154093.  I am not sure how to help because I do not fully understand what exactly you are trying to accomplish, and what specific part of your project you are experiencing problems with.  Can you please explain in more detail what your goals are trying to achieve, what steps are involved, and what step(s) you are encountering problems with?  What kind of "tool" are you trying to build...an iLogic rule, a VBA macro, an Inventor AddIn, a standalone .exe application, etc.)?  Do you have existing code you are attempting to work with that is throwing errors?  If so, what type of code is it, and can you post the code here, either as a text file, or directly in a code window, so we can review it.  Also, can you post the contents of any error messages here in English for us?  If you do post something, make sure it does not contain personal or proprietary info you do not want to share.  It sounds a little bit like you are trying to put 3 PartsLists on a single drawing sheet, all for the same model.  Is that correct?  If so, do you mean you want to break one large parts list up into 3 separeate sections, or 3 different versions of the same parts list?
Wesley Crihfield
(Not an Autodesk Employee)
