Parts Visibility on View
Message 1 of 9
Does anyone have an idea on how to manage the visibity of parts on a particular view?
For example, in a view there 10 parts appeared. I would like to make only selected parts visible on the said view.
I have the manual steps on how to hide them but when I try to code it using the said step, the parts on the model file were hidden not in the view.
I use oView.ReferenceDocumentDescriptor.ReferenceDocument in traversing the parts but this refers to the model file.
Here is my code:
Set ViewDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
For Each ViewOccurence In ViewDocument.ComponentDefinition.Occurrences
        If Not nozzleName = ViewOccurence.ReferencedDocumentDescriptor.DisplayName Then
            ViewOccurence.Visible = False
Next
Please help me on this problem. I'm using VBA on this one. I just need a sample code for this.
Thanks in advance.
Replies (8)
Message 2 of 9
theo_bot
Isn't it possible to use viewreps? Thats makes it easier to control visibility of components in your views.
Message 3 of 9
Did you mean design view representation?
I have known view representation through the object browser but the only method i see on it regarding the visibility of the component are only HideAll and ShowAll method.
I want to have only selected components to be visible in the view.
Do you have a sample code for this?
Message 4 of 9
My Requirement is also almost same, but i am using VB.Net.
If anybody knows the solutions, it would be helpful.
Click Here to go to my posting
Message 5 of 9
skyngu
first, create design view representation as need in assembly model.
second, got assembly model in drawingdocument in vba or vb.net.
then, use this "ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Item("name of design view").Activate" to get design view.
try it, it should work.
Autodesk Inventor Professional 2019
Message 6 of 9
Some says that view representation is the solution for my problem so I'd tried to solve it using view reps but unfortunately I can't get the right code for view reps.
Do you have some code for this?Hope you can provide me.
Message 7 of 9
skyngu
it is on my reply.
Message 8 of 9
I mean in creating view reps. Sorry for the misunderstanding.
Message 9 of 9
theo_bot
I use this line in Ilogic, but it's coming from the APi help so it shout work in VB
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Add("newviewname")
