Parts list as parameter
p.kaminskiG7KX4
p.kaminskiG7KX4
Good Morning,
I would like to ask for help.
There is movie about configurators in Inventor:
https://www.youtube.com/watch?v=sBZdAJh9NYM&t=315s&ab_channel=AutodeskPolska
In 0:25 user picks any motor model from list from parameters table. How can I link parts to parameters in assemblies to make similar configurator?
theo.bot
They create a text parameter and filled it with the names of the components.
When you create a rule to place a component, you can dynamically create the name of the file, based on the text parameter.
Or create a rule with a select case definition, for each case (the value of the text parameter) you can add some code to place or replace a component.
