partDocument.Save trigger OnSaveDocument event
Frederick_Law
Mentor Mentor
Frederick_Law
I have addin to change part file BOM Structure to Reference when a new file is saved with "Master" in the name.
It worked since IV 2012 to IV2020.
After upgrade to 2023.2 it cause IV to crash.
I traced to problem to PartDocument.Save().
It trigger OnSave event and cause an endless loop.
If I can get the new filename Before save, I can avoid the Save again.
Or anyway to avoid event trigger?
Private Sub M_ApplicationEvents_OnSaveDocument(
        oDoc As _Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap,
        ByRef HandlingCode As HandlingCodeEnum) Handles M_ApplicationEvents.OnSaveDocument
Dim oPartDoc As PartDocument
'Cannot get new filename Before
If BeforeOrAfter = EventTimingEnum.kAfter Then
    'Check if new file, kAfter FileSaveCounter = 1
    If oDoc.FileSaveCounter = 1 Then
        If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            If (InStr(oDoc.DisplayName, "Master", CompareMethod.Text)) > 0 Then
                oPartDoc = oDoc
                oPartDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
                Saved = True
                'IV2023 trigger OnSave event
				oPartDoc.Save()
End Sub
WCrihfield
Hi @Frederick_Law.  Interesting paradox scenario.  I assume you are already aware of how to use the Context (NameValueMap) portion of that method works, as explained in the online help documentation for it.  Maybe you could try looking at the ThisApplication.CommandManager.PeekPrivateEvent(kFileNameEvent, oInputObjectForCapture) method.  Just something related that comes to mind, but have not tried it in that scenario before.
Wesley Crihfield
(Not an Autodesk Employee)
Frederick_Law
I'll debug and watch the Context, not promising:
"When a document is saved for the first time, this value will be "" for the kBefore timing and the filename of the document in the kAfter timing."
I'll watch other names in the PartDocument and see if I can find what I need.
Problem is Save() didn't fire OnSave in IV2020 and before.
Only have problem with IV2023.
Frederick_Law
One of the Context give full path of the file being saved during BeforeSave.
I can cut the file name out and use it BeforeSave.
This way I can remove Save().
I tested Save2, still fire OnSave.
Context Item Name doesn't change during the loop.  So I can't check if I'm in a loop.
