Part Number driven by parameters
CCarreiras
Mentor Mentor
CCarreiras
Hi!
I have 2 parameters in a part (a spring), "diameter" and "Length".
I change these parameters with iLogic to build several springs.
Is it possible to update the "Part Number" Each time I change the parameters "diameter" and "length"?
I want to get the following:
Mola_Ø-65_L-140
Where 65 is the parameter value and 140 is the length value.
I tried with the code below,
iProperties.Value ("Project", "Part Number") = "Spring_Ø-"   Diameter    "_L-"    Length
but that returns: End of statement expected.
Any idea?
thank you
CCarreiras
Curtis_Waguespack
Hi carloscarreiras8703,
Try this:
iProperties.Value ("Project", "Part Number") = "Spring_Ø-"   &  Diameter   &  "_L-"   &  Length
I hope this helps.
Curtis
CCarreiras
That´s it!! So easy Smiley Happy
Thank you Curtis.
CCarreiras
