Parsing XML and extracting data for parameters in ilogic
ahmed.hagi
ahmed.hagi
I'm trying to parse an xml and assign the values from the xml to parameters in the document through an ilogic rule.
I can't seem to import the msxml2.dll or add it as a reference.
Is there another way to parse an xml, extract the data and set it to parameters in the document?
I don't want to use VBA because this needs to be linked to this template file and run when the user imports the xml from wherever they have it saved.
jjstr8
I suggest the .NET XML library.  You can work out the code details in a stand-alone app in Visual Studio first, where you have real debugging capability.  Once you have the code working, port it to iLogic.
AddReference "System.Xml.dll"
ahmed.hagi
Sounds like a good idea. I'll have to do that.
