ParentOccurrence seems broken in Inventor Professional R. 2018.3.8
Yadow
Yadow
Greetings,
I have an open assembly ("AssemblyTop"). In this assembly I have another assembly ("AssemblyMid"), and within that assembly I have several Occurrences of parts and assemblys ("AssemblyLowest" and "PartLowest").
I want to loop and get the ParentOccurrence.name of all of my "Lowest" Components, but I only get an error when I get to the "Debug.print oSubOcc.ParentOccurrence.Name" -part.
Am I missing something or is there something wrong in the API?
Code posted below.
Sub TestSubSubParentName()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oOcc As ComponentOccurrence
For Each oOcc In oDoc.ComponentDefinition.Occurrences
     If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
        Dim oSubAsm As AssemblyDocument
        Set oSubAsm = oOcc.Definition.Document
        Dim oSubOcc As ComponentOccurrence
        For Each oSubOcc In oSubAsm.ComponentDefinition.Occurrences
            Debug.Print oSubOcc.ParentOccurrence.Name 'This is where my code breaks for unknown reasons...
        Next
Next
End Sub
Thanks in advance.
JhoelForshav
Hi @Yadow
You must stay in the context of the top assembly. When you go in to the document of the subassembly, it's no longer an occurrence in the top assembly but o document object, hence not a parent occurrence.
Try this code:
Sub Test()
        'Dim oSubAsm As AssemblyDocument  -  DON'T DO THIS
        'Set oSubAsm = oOcc.Definition.Document  -  DON'T DO THIS
        For Each oSubOcc In oOcc.SubOccurrences
        Next
Next
End Sub
Yadow
Never Mind! I just found out by trying that I needed to use oOcc.SubOccurrences instead of o oSubAsm.Componentdefinition.Document.
Silly me.
Yadow
Thanks a lot 🙂
It was quite obvious once I got the mindset straight.
