Parametric TORI_Sketch pattern + revolution
Message 1 of 1
I want to create a parametric model in which the number of tori updates with a parameter. The issue is that radius along Y axis increases in each torus. That's why I created a pattern in the sketch (I know that it isn't the best idea but I didn´t know how to proceed other way)
Is there anyway to update the number of tori in the revolution?
Is it possible to create this geometry without using pattern in the sketch (an ilogic code or something similar)?
Check the images below, attached video or 3D (inventor 2017) for more detail.
Thank you so much.
Replies (0)
