Parameters,iLogic and Forms
davorxxx
davorxxx
Hello
What is the formula to align the police so that they are at the correct distance when I change
quantity of shelves, height of cabinets.
I can't seem to get that formula.
Thanks in advance for your help.
kacper.suchomski
Hi
If a parameter is to be dependent on others, then you must describe it in the form of an equation, not an absolute value.
Kacper Suchomski
johnsonshiue
Hi! I believe either the rule has to be changed a bit or the parameter expressions has to be changed. It should be doable but it is hard to comment further without seeing the files. Please feel free to share the files here.
Software Test Engineer
davorxxx
Hi! I am sending the files here.
johnsonshiue
Hi! The files are incomplete. But, I think I know what you are trying to do. I check the rule in the assembly. Here is the rule in your file.
Parameter("@Skeleton", "Panel_thickness")=Panel_thickness
Parameter("@Skeleton", "Shelf_QTY")=Shelf_QTY
Parameter("@Skeleton", "Distance_between_shelf") = Distance_between_shelf
Parameter("@Skeleton", "Width") = Width
Parameter("@Skeleton", "Height") = Height
Parameter("@Skeleton", "Depth")=Depth
RuleParametersOutput()
InventorVb.DocumentUpdate()
Unlike SWX, "@Skeleton" does not mean anything in Inventor. What you need to do is to place the skeletal part inside the assembly. Then replace the "@Skeleton" with the instance name of the skeletal part.
Many thanks!
davorxxx
Hi! I placed the skeleton part inside the assembly and changed the name.
But when I set any in the table FORMS (Cabinet) that I created
I want the height and quantity of shelves to be at the same distance inside the closet,
but I can't get it at all.
Thank you very much!
