parameter in title block
samspade
Message 1 of 11
samspade
Hi folks.
can't figure out where i am getting this wrong... i want to create a single file for all assemblies i create for a job so that i can put information in it that is the same for the whole job - job name, number, finish to be exact. I then want to export xml and then import xml to each assembly drawing for the folder. That part was very easy. now, i want to put those values into the title block, which i thought was a no brainer as i have placed custom iProperties in my title block on a regular basis. I can't get it to fill the value, however, my title block reads <JOBNUMBER> where it should be the value of the parameter JOBNUMBER.
methinks this is just a late in the week brain meltdown, but can anyone provide me the simple solution? in short, how do i get a custom iProperty to fill in with a  parameter value... and get it into my title block?
btw - i am familiar with editing the titleblock and selecting custom properties to pull from the list of properties
thank you in advance for any light you may be able to shed.
Replies (10)
Message 2 of 11
The iProperty must read =<JOBNUMBER>
Message 3 of 11
samspade
Yes, that was how I wrote it. And I get the funny f symbol, but not seeing it in the title block. I have a feeling it is something ridiculously stupid....! Yikes.
Thanks for trying
Sent from my Verizon 4G LTE Smartphone
Message 4 of 11
YOUR PARAMETER MUST BE MARKED FOR EXPORT ALSO
Message 5 of 11
samspade
The only check mark box i am seeing in the parameters dialog is for Key... seems like there was another one somewhere, sometime that is not there now. I am doing this all inside a dwg that has an assembly in it...
thanks for the help
Message 6 of 11
samspade
ok, there is no Export Parameter column, is that because it is a user parameter, or possibly because it is text vs. a number?
thanks again
Message 7 of 11
I don't do anything inside the drawing but iLogic will get you what you want
iProperties.Value("Custom", "JOBNUMBER")= Parameter("JOBNUMBER")
iLogicVb.UpdateWhenDone = True
Set an event trigger before save
Message 8 of 11
samspade
oh well i actually started out with this rule, and i do have an event trigger set up as well. i really don't get it. seems like it should just be so simple and it has become a 2 hour project...
thanks for trying
Message 9 of 11
samspade
forgot to put the rule in:
iProperties.Value("Custom", "JOBNAME") = JOBNAME
iProperties.Value("Custom", "JOBNUMBER") = JOBNUMBER
iProperties.Value("Custom", "JOBFINISH") = JOBFINISH
Message 10 of 11
Works fine for me
Message 11 of 11
samspade
ok, I added the word parameter like you said in the rule, and voila, it works now. i guess that was the deal breaker.
thanks for your perserverance and seeing me through to the bitter end!!
Thank you and Good Day!!
