Overrule parameter
Overrule parameter
jostroopers
Overrule parameter
jostroopers
I liked what help with making override parameters.
I've made a meander, see dwf and ipt.
In order to determine the respective distances of the strings I created parameters, S1, S2, etc.
Now I can enter any distance apart.
Now I made a new parameter "SteekOverRule" that has to override these parameters.
So if there is a value entered in this parameter must get the other parameters overrule and for all strings that measure adoption.
If this parameter is set to zero then the other parameters apply.
I know that with the if and elseif it must be possible but do not know when the parameter SteekOverrule returns to zero and the other parameters must be active.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
xiaodong_liang
Autodesk Support
Autodesk Support
I am struggling to understand "I know that with the if and elseif it must be possible but do not know when the parameter SteekOverrule returns to zero and the other parameters must be active."
I checked the part, SteekOverrule has only three avaiable values: 75, 105, 90. I have no idea when it can be zero.
Or,.did you want to watch when the param is modifed ? In Inventor API, you can use then event ModelingEventsSink.OnParameterChange. In iLogic, you could add the event trigger "Any Modal Parameter Change"
jostroopers
Hi Xiaodong
I already have a solution.
I made an extra parameter 000mm who is part of the parameter SteekOverrule.
I also make parameters S1_Old and use them in my form.
Then i made the ilogic rule.
If SteekOverrule = 0 mm Then
S1 = S1_Old
S2 = S2_Old
S3 = S3_Old
S4 = S4_Old
S5 = S5_Old
  Else
S1 = SteekOverrule
S2 = SteekOverrule
S3 = SteekOverrule
S4 = SteekOverrule
S5 = SteekOverrule
iLogicVb.UpdateWhenDone = True
Thanks for responding.
Mvg Jos
jostroopers
Here is the part with the ilogic rule
Mvg Jos
