Overiding Inventor shortcuts while Addin is active.
jaka73LU2
Message 1 of 1
jaka73LU2
I am making an AddIn which is using a windows form. I am trying to make a simple copy paste functionality on my form but I is not letting me.
If I try a random key combinantion like Ctrl+A for coping to the clipboard it works, but the combination Ctrl+C is does not. I am working in an assembly. I think Inventor somehow reserves this key combination for the copy function in the  assembly.
So my question would be, how can I override shortcuts in the assembly while the windows form is active or in focus?
Here is my code in the windows form:
' COPY AND PASET FUNCTIONALITY
    Private Sub Form1_KeyDown(sender As Object, e As KeyEventArgs) Handles MyBase.KeyDown
        ' Copy to clipboard when Ctrl+C is pressed
        If e.Control AndAlso e.KeyCode = Keys.C Then
            'If e.Control AndAlso e.KeyCode = Keys.C Then
            'g_konfiguratorForm.PrintToLog("Ctrl+C")
            Dim activeControl As Control = Me.ActiveControl
            If activeControl IsNot Nothing AndAlso IsWritableControl(activeControl) Then
                Clipboard.SetText(activeControl.Text)
        ' Paste from clipboard when Ctrl+V is pressed
        If e.Control AndAlso e.KeyCode = Keys.V Then
            'g_konfiguratorForm.PrintToLog("Ctrl+V")
                activeControl.Text = Clipboard.GetText()
    End Sub
    Private Function IsWritableControl(control As Control) As Boolean
        Return TypeOf control Is TextBoxBase OrElse
               TypeOf control Is ComboBox OrElse
               TypeOf control Is ListBox OrElse
               TypeOf control Is DataGridView
        ' Add more control types if needed
    End Function
Replies (0)
