Output Mono or Colour PDF file Using Inventor VBA
isocam
isocam
Can anybody help?
I have a VBA macro that can output a PDF file of a Inventor Drawing (idw or dwg) OK
What I want to do is output a detail drawing in "black & white" (Mono) and output a assembly drawing in colour.
Does anybody know if it is possible using inventor VBA and does anybody have an example how to do this???
Many thanks in advance!
Darren
basnederveen
Public Sub PublishPDF()
    ' Get the PDF translator Add-In.    Dim PDFAddIn As TranslatorAddIn
    Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.Value("All_Color_AS_Black") = 0 ' change to one for black and white
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4    End If
    'Set the destination file name
    oDataMedium.FileName = "c:\temp\test.pdf"
    'Publish document.    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
You can make either a button for B&W and one for color, or create a script which recognizes if a view in the first sheet is referencing and assembly or a part.
btw this is taken directly from the samples, you can look in the help function in inventor for this
